CV Bolt stuck |
CV Bolt stuck |
stuttgart46 |
Jun 2 2012, 06:26 PM
Member Group: Members Posts: 305 Joined: 17-December 07 From: Santa Monica, CA Member No.: 8,474 Region Association: None |
Trying to remove the engine and the last CV bolt is stripped. I can't seem to grab it with vice grips either. Anybody have any advice?
TheCabinetmaker |
Jun 2 2012, 06:33 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Drill the head off, and the bolt will come out by hand, or use a hammer and chisel to make a notch in the outside of the bolt head, then turn the chisel side ways in the notch and use the hammer to try and loosen the bolt. If you have a sawsall or a cut off tool, you can cut the head off the bolt.
kkid |
Jun 3 2012, 12:34 AM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
clean the bolt and pipe wrench?
etcmss |
Jun 3 2012, 03:39 AM
etcmss Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest |
I've cut the head off with dremmel and after CV joint is removed worked the remaining bolt out with WD 40 and vice grips. if all else fails have cut it off and drilled out and tapped.
gary |
Bartlett 914 |
Jun 3 2012, 07:09 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Really try to get it out without cutting off the head. If you cut off the head and cannot get the remaining screw out, you will have difficulty taking off the CV. Vice grips or pipe wrench. The smaller vice grips may work better than the larger ones. They seem to bite better.
Mark Henry |
Jun 3 2012, 07:31 AM
Hammer a larger hex key in and with vicegrips turn them both at the same time.
stuttgart46 |
Jun 3 2012, 09:33 AM
We were in a bit of a hurry so we cut it off with the sawzall.
Thanks for all the tips. Now a different member here has a new 2.0 that he'll be installing soon and I have room for a new 6. |
rhodyguy |
Jun 3 2012, 09:38 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
try a small basin wrench. found in the plumbing dept of your local hardware store.
k |
Lo-Fi Version | Time is now: 1st June 2024 - 04:15 PM |
