Nickie comes to Long Beach |
Zeke |
May 11 2003, 08:33 AM
Never left, but not right.... Group: Members Posts: 381 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
No, not the guy in the black L&N engineering shirt. That's Steven, who drove Charles Navarro down from Pasadena in his 2002 Boxster S. Nickie rode in the trunK.
Attached image(s) |
Bleyseng |
May 11 2003, 08:35 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
102's?
What are you going to do with them? Geoff |
Zeke |
May 11 2003, 08:38 AM
Can you not load 2 pics in one post? Here's a close up of Nickie and his friends the studs, in the bag which unfortunately you can't see. Geoff, I don't know what size exactly, but it wasn't a 96, that's for sure. CN was kind enough to bring Nickie down for a 914 get together. Nickie enjoyed himself. Yes, he was all by himself. BTW, I'm not doing anything with Nickie in the near future.
Attached image(s) |
PatW |
May 11 2003, 12:16 PM
Wassup? Group: Benefactors Posts: 565 Joined: 19-February 03 From: Rocklin, CA Member No.: 317 Region Association: Northern California |
Are them those hot set-up cylinders that Jake Raby is offering for Type IV's...
Jeff Krieger |
May 11 2003, 12:30 PM
Unregistered |
I'm glad to see that there are still companies producing (and improving) parts for our beloved air-cooled motors.
Aaron Cox |
May 11 2003, 12:49 PM
are we talking nikasil?
nickie=nikasil? |
Mark Henry |
May 11 2003, 12:59 PM
Yep, nikasil.
Raby will install them, but LN manufactures and sells them. With pistons and head studs $3000. I think I’ll go with bored out 96’s |
bernbomb914 |
May 11 2003, 04:51 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
Those nickkies are 106's Charles said they will run cool and long, will work as well as 96's. They are also developing a new head to match with better flow and cooling. he said the market is big in midgets. should make big HP for a four about $3000 for each. get a good cam good crank clean up the case and bolt together.
Attached image(s) |
bernbomb914 |
May 11 2003, 04:53 PM
more
Attached image(s) |
bernbomb914 |
May 11 2003, 04:55 PM
more
Attached image(s) |
bernbomb914 |
May 11 2003, 04:56 PM
and
Attached image(s) |
bernbomb914 |
May 11 2003, 04:58 PM
that was zeke's race car
Attached image(s) |
Jeff Krieger |
May 11 2003, 04:59 PM
Unregistered |
QUOTE(bernbomb914 @ May 11 2003, 03:51 PM) ... They are also developing a new head to match with better flow and cooling. I vote for heads with OHCs. |
bernbomb914 |
May 11 2003, 05:01 PM
and
Attached image(s) |
bernbomb914 |
May 11 2003, 05:02 PM
last
Attached image(s) |
Aaron Cox |
May 15 2003, 05:43 PM
QUOTE(Jeff Krieger @ May 11 2003, 02:59 PM) QUOTE(bernbomb914 @ May 11 2003, 03:51 PM) ... They are also developing a new head to match with better flow and cooling. I vote for heads with OHCs. hey, while we are at the wishing well, i want four valves a cylinder, DOHC, etc etc. (IMG:style_emoticons/default/biggrin.gif) how would one go about doing an OHC head for a pushrod engine? external belt/chain? |
Mueller |
May 15 2003, 06:01 PM
LN is making brand new heads, supposedly, they are going to be good for 200-300hp out the box....cash in your 401k for a set (IMG:style_emoticons/default/smile.gif)
I look forward to seeing what kind of reliable power can be extracted from these Type IV based motors Whos green 914 is that? VERY NICE 914 (IMG:style_emoticons/default/mueba.gif) The easiest way to drive the cams in a OHC motor is belts (dry) less work and expense. |
Aaron Cox |
May 15 2003, 06:24 PM
but if the belt(s) failed, would the engine have an interferance problem....such as valves smacking pistons and so forth.?
i know it is purely speculation as to a ohc head....take an educated guess |
Mueller |
May 15 2003, 06:31 PM
Depends on the design of the motor .....not all engines are "interferance" motors.
piston design, valve lift, combustion chamber all makes a difference.... My old Volvo 745 had a belt let go...no problems...if the belt lets go in my newer Volvo, big repair bill would be in store. |
Aaron Cox |
May 15 2003, 06:34 PM
i too have two volvos!
a 240 a 940 turbo *both non interferance motors |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:54 PM |
