e-brake lever removal, '71 |
mepstein |
Jun 3 2012, 06:33 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Tell me how or point me to a good thread. Thanks, mark
bcheney |
Jun 3 2012, 07:55 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Tell me how or point me to a good thread. Thanks, mark Are you talking about the actual lever in the cabin or at the end of the cables out at the calipers? If at the caliper side..loosen the nuts that are on the cable where they begin their journey into the cabin from the engine bay side....I think that will create enough slack in the cable so you can remove cable from where it attaches the caliper. If are talking about the lever...it comes out easily by loosening the retaining nut. |
mepstein |
Jun 3 2012, 07:57 PM
Tell me how or point me to a good thread. Thanks, mark Are you talking about the actual lever in the cabin or at the end of the cables out at the calipers? If at the caliper side..loosen the nuts that are on the cable where they begin their journey into the cabin from the engine bay side....I think that will create enough slack in the cable so you can remove cable from where it attaches the caliper. Lever in the cabin. |
jimkelly |
Jun 3 2012, 08:02 PM
mepstein |
Jun 4 2012, 04:22 AM
Probably but I can't find the bolt. |
bcheney |
Jun 4 2012, 05:13 AM
The bolt is hard to see if the seats are in the car. Here are a couple of reference pics to help you out. It's the 8mm bolt all the way to the right in both pics. The lever pivots on the point (stud shaft) just to the left of the bolt. The bolt will be under the lever and out of sight with the seat in. Not sure if you will have to take the seat out to get to it. My seats are out and it's been a long time since I have looked at this with the seats in...you know how these restoration projects go! Many years pass then it takes you some time to remember how things go back together and it what order. Attached thumbnail(s) Attached image(s) |
mepstein |
Jun 4 2012, 05:36 AM
Probably but I can't find the bolt. The bolt is hard to see if the seats are in the car. Here are a couple of reference pics to help you out. It's the 8mm bolt all the way to the right in both pics. The lever pivots on the point (stud shaft) just to the left of the bolt. The bolt will be under the lever and out of sight with the seat in. Not sure if you will have to take the seat out to get to it. My seats are out and it's been a long time since I have looked at this with the seats in...you know how these restoration projects go! Many years pass then it takes you some time to remember how things go back together and it what order. Perfect. Thank you. Mark |
Lo-Fi Version | Time is now: 8th June 2024 - 05:24 AM |
