what type of oil line to run to front cooler? |
moparrob |
Jun 3 2012, 10:19 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
Thanks to the help and encouragement of local member "Jeff" I have made more progress in getting my cooling system finished up for the six conversion project.
After we got the external thermostat mounted we decided on which way I was going to route the lines. I took an old garden hose and fished it through the longs and it exited up by the defroster where the heater hose comes out. Since I will not be using heaters on this car it will not be a problem. Here is a look at the mockup so far. (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1338783555.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1338783555.2.jpg) This is the front trunk with the new fuel system installed. I had to re-mount everything slightly lower than before due to the fact it is a gravity feed system. The entire fuel system is done in 3/8 inch hard-line now. (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1338783555.3.jpg) So the question I have is what type of oil lines should I run from the thermostat to the front cooler and back to the thermostat? I was originally thinking about using braided lines but now I'm thinking about the blue silicone lines, since it seems as though some members have used this with success. I'd appreciate any input you may have on arriving at that decision. Thanks in advance. |
wingnut86 |
Jun 4 2012, 05:53 AM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
2 of the 3 images are awesome (IMG:style_emoticons/default/smile.gif)
Can you reshoot the front trunk image with no flash maybe? Do you have a list of parts shown up there as well? Holley? Great image closeups. Thx, Dave |
McMark |
Jun 4 2012, 08:34 AM
You probably won't be able to make the bends you're making with steel braided line, so that's out.
The black nylon braided works and the blue line works. Which ever one makes you happy and fits your budget. |
ape914 |
Jun 4 2012, 11:56 AM
red locktite Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
Aeroequip and or Fragola makes a nice Nomex covered oil hose, has a tighter bend radius than there stainless covered hoses. good stuff, and it wont abraid thru the cars metal if rubbed as the stainless does. give that a try. I am running there AN-10 Nomex hose and like. Alos have their Nomex AN-8 in another car, great stuff.
SirAndy |
Jun 4 2012, 12:08 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
This stuff works great:
http://www.914world.com/uploads/4281_b1.pdf (800k) The blue hose i used is their "836 Hi-Temp, Heat-Resistant Hose" Operating range: up to 250 psi, 300 deg. F Burst pressure: 1000 psi http://www.914world.com/bbs2/index.php?s=&...st&p=893543 (IMG:style_emoticons/default/bye1.gif) |
moparrob |
Jun 4 2012, 09:43 PM
So (with respect to our application) is it basically a cosmetic decision between the Nomex, black braided and the blue hose? Each seems to be overkill for the limited temperature and pressure in question, no?
Are the fittings or method of attachment any different between the blue, Nomex and black braided? Is one stronger than another? Thanks. Here is an old picture of the front trunk before I re-located the pump and filter lower... (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1338867784.1.jpg) Is that better? |
Lo-Fi Version | Time is now: 8th June 2024 - 03:39 AM |
