Ignition wires ... "The Good the Bad, the Ugly" |
Eddie914 |
Oct 15 2004, 04:22 PM
Unregistered |
What's a good value for plug wires for a '77 2.7? (Stock ignition)
I discovered the '71 914/6 (2.7 conversion with 40IDA Webers) needs new ignition wires (spark plug wires) at the track last week. It rained very hard all day and the engine developed a bad miss/backfire. I'm running megaphones at the track and the following drivers, told me they could see flashes of fire in the pipes when the car backfired. At first I though it was the infamous plugged idle jets. I double-checked the jets and the miss was still there. I have watershield aircleaner hats so I wasn't worried about sucking water into the carbs. I didn't think about all the wiring getting wet. Once I got the car home and dried out the miss went away (too bad the pulled exhaust stud didn't fix itself). Anyone have a time-sert tool I can rent? Eddie |
Ferg |
Oct 15 2004, 04:28 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I just ordered a set of magnecores from this place, cheepest I found had them in 4 days.
I have a 77 2.7 also but with cis. http://www.apexperformance.net/cartgenie/p...?pid=130&cid=10 |
Eddie914 |
Oct 15 2004, 04:33 PM
Unregistered |
Red, Blue or Black?
8.5mm, 8.0mm or 7mm? Is a there a big difference? |
Ferg |
Oct 15 2004, 04:38 PM
Red, cause it's purtier, and 8.5 cause someone that knows more than me told me so.
Ferg (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 02:31 PM |
