Horn not working? Also tips on replacing rear main seal, My high beams won't stay on either? |
JRust |
Jun 6 2012, 11:36 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
The horn isn't working on my LE. The wire is there & connected but I get nothing. It's definately connected to the horns also? What would you suggest to check next?
I also have a leak from the rear main seal. I'm going to pull the drivetrain saturday to replace it. I'll replace the flywheel O-ring along with the Flywheel pilot bearing/felt washer & the flywheel crush washer. The rear main seal is the main thing. Any tips or tricks on getting it to seal properly? On my high beams they will come on if you hold the lever back. They will not click to stay on though? As always thanks for the help |
reharvey |
Jun 6 2012, 11:41 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Just my 2cents but I've had much better luck with the Victor Reinz rear seals.
McMark |
Jun 6 2012, 11:56 AM
Check the horn relay. It's up on top of the fuse panel. It's the one that has the red, red/white, brown/white, black/yellow wires. Should be on the very left.
JRust |
Jun 6 2012, 12:44 PM
Check the horn relay. It's up on top of the fuse panel. It's the one that has the red, red/white, brown/white, black/yellow wires. Should be on the very left. Thanks Mark for giving me the wires too. I think I can manage to get the right relay with that (IMG:style_emoticons/default/biggrin.gif) . How about my high beams not clicking on but still will flash with the lever? |
sixnotfour |
Jun 6 2012, 02:44 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
headlight relay on the fuse panel, try a different one or open it up and clean the points.
slothness |
Jun 6 2012, 03:03 PM
It's business time Group: Members Posts: 110 Joined: 7-October 04 From: Valencia, CA Member No.: 2,906 Region Association: Southern California |
Stock steering wheel or aftermarket? My whole steering column was mucked up by myself years ago installing my momo wheel. I had that high beam issue because there are two contacts the turn signal switch hits, one of them was pulled too far back and would never allow the high beam or low beam to click over...so I never drove at night. Plus apparently reinstalled it incorrectly and I sheared the horn button wire when I went out for a drive. Had a nice "little miss sunshine" moment when I made that left and there wasn't a shoulder to pull off on for 2 freaking blocks with my sad little horns blasting. God that was embarrassing...and this was all after getting honked at when I took a minute to crunch the stupid thing into first gear. (IMG:style_emoticons/default/headbang.gif)
76-914 |
Jun 6 2012, 03:23 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Jamie, I went thru that until I found this. The seal is $40 w/ shipping but it is a little longer = greater sealing area. http://www.gowesty.com/ec_search_results.p...ase=029-105-245
JRust |
Jun 10 2012, 08:55 PM
headlight relay on the fuse panel, try a different one or open it up and clean the points. I had the Engman Fuse panel upgrade. While I had those relays out I decided I would just do the upgrade. It would be easy enough to change back so I wasn't to worried about it not being OE. Before I did I took out all the relays cleaned them up & switched them around. It made no change with the high beam. Same with the horn. Still nothing from the horn. That was a far as I got. I drove it up to Seattle for the weekend. It ran great the whole time & I even went topless the last few hours. Was overcast when I left but just kept getting nicer as I drove. So when I stopped for gas off came the top. Of course I got the usual nice car for a few folks. Then had the guy who had one stop. Talked for a few minutes & finally got on the road again. Was a nice 2 hours with the top off. Been quite a while since I have enjoyed a drive that much (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:29 AM |
