markyb |
Member ![]() ![]() Group: Members Posts: 100 Joined: 27-November 11 From: Rochester, Michigan Member No.: 13,823 Region Association: None ![]() |
![]() I'm getting a bit of vibration and wiggle in the rear of the car at 60-65 MPH, irregardless of the RPM or gear that i'm in, and smoothes out over 65MPH. This would lead me to believe that it's something wrong from the trans shafts outward. Any suggestions on how to check play on the wheel bearings without a big teardown? Other ideas? Wheels and tires are in good shape and balanced... Thanks |
siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,464 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
I'd try rotating the wheels to double check that that's not the problem. For me, it seems like tire balancing is *always* the problem for these sorts of things.
-Steve |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Check your suspension attachment points!
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
wheel and tire balance issues no ?.... (IMG:style_emoticons/default/smile.gif)
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,318 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Check your suspension attachment points! (IMG:style_emoticons/default/agree.gif) Check for a cracked suspension console on the passenger side rear. It's common for rust to eat through there ... (IMG:style_emoticons/default/dry.gif) |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,350 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
What you describe is classic out of balance tires. How long ago were the wheels balanced? What kind of weights did they use? The clamp on weights won't stay on the Mahles. The glue on weights won't stay on a wheel with dirt, grease, brake dust, and grime on them. Balance jobs sometimes don't last very long. One panic stop and a small flat spot on a tire will throw the balance off.
markyb |
I'll try all of the above, stay tuned....
The wheels have tape weights, and balanced about 1000 miles ago. I'm going to try a different tire shop, some of the nearby ones don't impress me at all, and I don't like the way they handle rims around the mounting equipment, tossing them on and off without too much care. While the tires are off I'll do a little snooping around underneath and see if everything feels tight. Hussey said that this car is all original, that might mean there's some things needing attention in the suspension. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
at least you don't have to worry about the employees taking the center caps off with by placing a screwdriver handle against the center of the cap and smacking the the driver with a hammer. after one experience i always do the cap removal myself.
k |
6freak |
the colored dots are on new tires for a reason
(IMG:style_emoticons/default/smile.gif) |
larss |
Member ![]() ![]() Group: Members Posts: 431 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia ![]() |
I had about the same problem with my 914, after trying a ot of wheel balancing I found the problem beeing the surface between the disc and rear hub not being perectely clean. After cleaning the surfaces the vibrations were gone.
Lars S |
markyb |
After a visit to a more professional shop for tire rebalancing, VOILA! I now have a smooth ride. The tape weights are now on the backside of the rim too for a cleaner look. Now on to other stuff as the ass end on my '75 appears to be sagging a bit. The springs are most likely original so I'll need to measure up bumper height after allowing for a slight difference in the current tire height (185/65-15).
Any suggestions on what brand and where to buy for a set of new rear springs? I looking to maintain a near-stock ride. The frame and other suspension components are rock solid form what I can gather. Thanks for all of the ideas, my wallet is much happier that it was something so simple. |
MikeM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada ![]() |
You are very lucky...mine has the same shimmy and I can't figure it out. Mine shimmies on the hoist so it can't be wheel balance and I've tried everything!!!
Glad yours is fixed!!! Mike |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,088 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
After a visit to a more professional shop for tire rebalancing, VOILA! I now have a smooth ride. The tape weights are now on the backside of the rim too for a cleaner look. Now on to other stuff as the ass end on my '75 appears to be sagging a bit. The springs are most likely original so I'll need to measure up bumper height after allowing for a slight difference in the current tire height (185/65-15). Any suggestions on what brand and where to buy for a set of new rear springs? I looking to maintain a near-stock ride. The frame and other suspension components are rock solid form what I can gather. Thanks for all of the ideas, my wallet is much happier that it was something so simple. 100lb springs from pelicanparts.com - I just bought a set and I'm happy with the ride and ride height. Car is all stock. |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
A pic from behind the car may be enlightening. See if your wheels are even and not leaning.
markyb |
![]() ![]() O yeah, they be leanin' a bit. You can't really see it on the full ass shot, but next to the framing square it shows. |
Dr Evil |
From more of a distance you can usually see one or both have bad camber. Hard to tell in those pics. Jack up the end of the car and wiggle the wheel from top and bottom looking for play in the arm.
6freak |
Mine shimmies on the hoist so it can't be wheel balance you mean when the wheel`s arent turning and the motor`s running it shimmy`s....or in gear with the motor running.....out of balance wheel`s and tire`s really show up when there`s no down force on the tire which = mass and mass dampen`s vibration...JMPO (IMG:style_emoticons/default/smile.gif) |
MikeM |
I mean when the motor is running and the wheels are turning.
I have tried 2 other sets of wheels and tires....same thing. You were going for a bent rim...right? Thanks, Mike |
TheCabinetmaker |
Not an engineer, but I would think anything other than a perfectly balanced wheel would bounce with no load on it. Any slop in the suspension is surely gonna show up.
Lo-Fi Version | Time is now: 23rd September 2025 - 12:55 AM |
