Car dies after hard stop |
michael7810 |
Jun 14 2012, 08:06 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I have Weber IDF40s and the engine dies after a very hard, just short of locking up the wheels, stop. It runs good and doesn't quit any other times. Anyone else have this problem? Could it be the float levels?
ThePaintedMan |
Jun 14 2012, 09:09 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Positive someone else's opinion is better than mine on this one, being a newbie to carbs, but thats exactly what it sounds like to me. I had an Holley with a misadjusted float on my old T-Bird and it did the same thing. Might try taking them apart and re-setting it to specs/checking float level.
-George |
IanJ |
Jun 15 2012, 02:38 AM
Member Group: Members Posts: 90 Joined: 28-December 05 From: Perth, Western Australia Member No.: 5,327 Region Association: Australia and New Zealand |
Have you checked the clutch adjustment (or even make sure the mat isn't stopping the pedal from going right down)
I had this problem recently...so you never know! |
rhodyguy |
Jun 15 2012, 02:08 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
don't tear your carbs apart. i think its something else. how long has this been happening? since you've owned the car? if you are rolling in neutral and hit the binders does the car still die?
yeahmag |
Jun 15 2012, 02:32 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Yes it could. Or a "sinking" float. That is assuming the same thing happens if you pop it in neutral and do a hard stop.
I have Weber IDF40s and the engine dies after a very hard, just short of locking up the wheels, stop. It runs good and doesn't quit any other times. Anyone else have this problem? Could it be the float levels? |
Dr Evil |
Jun 15 2012, 02:51 PM
Does your electrical stay on? Similar issue happened to someone else and it was found that he/she had too much crap on the key ring and gravity would pull all that crap forward and turn the car off, then swing back and turn stuff on with a dead engine.
A bad start switch can do this without all the junk on the ring. It is an unlikely scenario, but I thought about it so posted it. |
ThePaintedMan |
Jun 15 2012, 05:58 PM
Wow, those are all really good points too! I think Kevin's question was really pertinent - did it just all of a sudden start doing this? It is doubtful a carb's float level would all of a sudden change, unless the float itself was leaking. Right?
michael7810 |
Jun 16 2012, 07:17 AM
I've only owned the car for a couple years and yes the problem has been occurring since day 1. What I first noticed was the oil pressure light would come on so I don't think the electrical is cutting off...I only use 1 key with no key ring when I drive it. Also if the power cycles the A/F gauge would go through it's startup process and that is not happening. I have not tried it in neutral but I know it does happen with the clutch in. I'll try it in neutral the next time I'm out. I'll see if the A/F goes way lean/rich during the hard stop and maybe I'll be able to tell if it's fuel related.
Kirmizi |
Jun 16 2012, 10:45 AM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
How are the fuel lines below the tank? Any kinks or twists?
Mike |
michael7810 |
Jun 16 2012, 01:33 PM
I have replaced the tank fuel lines so I think they are OK. I don't think it would be fuel starvation if the float bowls were full to begin with. Hopefully the A/F meter will tell me if it's a fuel problem. I'll need a copilot to watch the meter while I slam on the binders.
Lo-Fi Version | Time is now: 9th June 2024 - 07:04 PM |
