WTB Sail trim fasteners, Sail Trim Fasteners |
xperu |
Jun 15 2012, 03:31 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I'm not sure what they are called exactly, but I am looking for the R&L side sail trim fasteners that hold the side trim to the body at the trunk level/bottom of the sail trim peice. Thanks. Mike
TheCabinetmaker |
Jun 15 2012, 05:31 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I have a few. Do you need them for both sides?
Mikey914 |
Jun 15 2012, 06:59 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If you can't find used dealers still have them available.
nickp997 |
Jun 15 2012, 07:08 PM
Newbie Group: Members Posts: 16 Joined: 17-June 11 From: Texas Member No.: 13,207 Region Association: South East States |
I'm not sure what they are called exactly, but I am looking for the R&L side sail trim fasteners that hold the side trim to the body at the trunk level/bottom of the sail trim peice. Thanks. Mike Once Mike gets what he needs, I could use same for my right side....hope there are enough to go around. |
TheCabinetmaker |
Jun 16 2012, 06:31 AM
gotcha covered nick.
TheCabinetmaker |
Jun 16 2012, 09:34 AM
I have noticed (when removing these clips) that there is generally a blob of urethane or butyl on the top of the clip, and a small piece of double side tape on the very end of the trim. I think this was meant to help the end of the trim stay in contact with the body during high speeds.
Jeffs9146 |
Jun 16 2012, 12:54 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I have noticed (when removing these clips) that there is generally a blob of urethane or butyl on the top of the clip, and a small piece of double side tape on the very end of the trim. I think this was meant to help the end of the trim stay in contact with the body during high speeds. The Butyl was "intended" to keep the water from the tires from passing throught the holes in the body at the clips! |
TheCabinetmaker |
Jun 16 2012, 02:37 PM
I have noticed (when removing these clips) that there is generally a blob of urethane or butyl on the top of the clip, and a small piece of double side tape on the very end of the trim. I think this was meant to help the end of the trim stay in contact with the body during high speeds. The Butyl was "intended" to keep the water from the tires from passing throught the holes in the body at the clips! I would have thought the same, except its on the top of the clip in contact with the back of the trim. |
Jeffs9146 |
Jun 16 2012, 03:28 PM
I have noticed (when removing these clips) that there is generally a blob of urethane or butyl on the top of the clip, and a small piece of double side tape on the very end of the trim. I think this was meant to help the end of the trim stay in contact with the body during high speeds. The Butyl was "intended" to keep the water from the tires from passing throught the holes in the body at the clips! I would have thought the same, except its on the top of the clip in contact with the back of the trim. I think they would push it into the hole from the top then pop in the clip or visa versa! Just trying to keep the water from passing through the hole! |
Lo-Fi Version | Time is now: 1st June 2024 - 10:50 PM |
