Ignore this post |
Ignore this post |
tornik550 |
Jun 18 2012, 07:56 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
My alternator hasn't been working for a long time. I have rebuilding my engine so I never needed one. I replaced it tonight with a new Bosch 55a (what a pain). I hooked everything up and now when I go to hook up the battery- the wire arcs across to the battery post when I try to hook it up- wtf!!! I am an electrical idiot (along with other things). Anything is possible. I have made no other changes other than the new alternator. Inside the alternator, I did have to hook up the harness wires. I hooked up three things on the inside of the alternator- the big red wire to the area pictured, the wire from the black box on the alternator to the area arrowed and the obvious three pronged plug. There was a rubber boot around the red plug that was brittle and I suppose may not be insulating the ring connector well however I dont see how that would be a big deal.
Attached image(s) |
Lennies914 |
Jun 18 2012, 08:04 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
How did you determine that your original alt. was bad? I would unplug the three prong harness and/or remove the voltage regulator off the relay board and see if it still arcs.
infraredcalvin |
Jun 18 2012, 08:06 PM
Distracted Member Group: Members Posts: 1,528 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I don't recall what my 914 alt looks like, but I just pulled the alt out of my 930 yesterday, there was a big ground strap in addition to the 3 wires I pulled. Are you missing a ground?
tornik550 |
Jun 18 2012, 08:09 PM
Well- it turns out that I am not just an electrical idiot- I must be just a general idiot. I forgot to hook up the three prong plug on the relay board. Damn it.
My goal is to someday post something that is half way intelligent. Maybe someday. |
Dr Evil |
Jun 18 2012, 08:23 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/av-943.gif) With a title like "Ignore this post" I have to look.
markb |
Jun 18 2012, 08:28 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
shuie |
Jun 18 2012, 08:33 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
This post?
Mark Henry |
Jun 19 2012, 08:02 AM
This problem is caused by a RTMS failure. (IMG:style_emoticons/default/smile.gif)
Chris H. |
Jun 19 2012, 08:17 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Can't..............ignore............... (IMG:style_emoticons/default/hissyfit.gif)
Lo-Fi Version | Time is now: 9th June 2024 - 01:25 PM |
