Hub swap, Swapping out original 4 lug for 5 |
ZacB20 |
Jun 19 2012, 07:55 PM
Newbie Group: Members Posts: 17 Joined: 6-June 12 From: Washington Member No.: 14,530 Region Association: None |
Need to swap out the original 4 lug for new 5 lug. Front and rear obviously. How much will it cost? What hubs should I use and who makes them? Thanks for the support guys!
brant |
Jun 19 2012, 08:01 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the front "hubs" don't interchange
you need to change the strut on the front and possibly the a-arm while your there (not absolutely required but gives you stiffer suspension) (recommended to replace the shocks bushings, ball joint, sway bar, and wheel bearings... oh... yeah replace the brakes, new rotors, different calipers, rebuild teh calipers, new pads, and brake lines while your in there. The 911 brakes bolt to the 911 struts and give you a vented front brake) the rears will interchange although it would be cheaper to have yours welded, machined, and drilled into a 5 bolt..... (you have to replace the rear bearings while your there) probably 1K if you do your own work... maybe 1,500 with shocks and rebuilding the calipers. |
ZacB20 |
Jun 19 2012, 08:04 PM
Would 4 to 5 lug bolt on wheel spacers handle the 550ish horse I'll be making when it's all said and done? Seems like with the right studs and spacers it could work
brant |
Jun 19 2012, 08:06 PM
Would 4 to 5 lug bolt on wheel spacers handle the 550ish horse I'll be making when it's all said and done? Seems like with the right studs and spacers it could work nope pretty frowned upon and the spacers eat up your tire clearance so with spacers you really need flares (ie: body work/paint $$$) |
ZacB20 |
Jun 19 2012, 08:12 PM
Alright. Thanks for the quick replies btw!!
So even the stock 4 lug with custom 1 piece wheels and tougher studs won't hold up to 550 horse? I really would like to avoid having to swap struts and hubs. |
ZacB20 |
Jun 19 2012, 08:13 PM
Also I already plan on getting a body kit for 9" fronts and 11" rears
brant |
Jun 19 2012, 08:25 PM
you could run the 4cylinder stock stuff.. minus the spacers
but the brakes and spring rates will be inadequate for that kind of power.... plus you would really need to rebuild all of the stock stuff (calipers, brake hoses, special pads, ball joints, and shocks) at the same cost as the 911 parts. |
SirAndy |
Jun 19 2012, 08:29 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So even the stock 4 lug with custom 1 piece wheels and tougher studs won't hold up to 550 horse? Let's put it this way, you will not find a single racing or autocross venue that allows 4 lug to 5 lug bolt-on adapters. And if that's not enough, with bolt-on adapters, you're still running the /4 brakes that were build for a sub 100 HP car. I'm not sure how much you value your life (or that of others), but if you're planning on pushing 500+ HP in a 914 and at the same time you cringe at upgrading your suspension and brakes, you might be better off buying a Mustang. (IMG:style_emoticons/default/biggrin.gif) |
ZacB20 |
Jun 19 2012, 08:41 PM
I am upgrading the brakes and suspension definitely. I am just looking at the simplicity side of things. Which 5 lug struts and rear hubs should be used? Brake calipers? I already have springs and rear shocks picked out.
brant |
Jun 19 2012, 08:44 PM
the front "springs" are torsion bars
the 911 stock ones are bigger "stiffer" than stock 4 cylider ones... you can upgrade from there to a stiffer spring rate. you want to balance somewhat your rear spring rate to your front rates... |
ZacB20 |
Jun 19 2012, 08:50 PM
the front "springs" are torsion bars the 911 stock ones are bigger "stiffer" than stock 4 cylider ones... you can upgrade from there to a stiffer spring rate. you want to balance somewhat your rear spring rate to your front rates... I know there's a torsion bar stock. I've left it their but added coil springs also. It's actually not as ghetto as it sounds. It's been done on multiple different car builds including Porsches and VWs |
brant |
Jun 19 2012, 09:00 PM
the front "springs" are torsion bars the 911 stock ones are bigger "stiffer" than stock 4 cylider ones... you can upgrade from there to a stiffer spring rate. you want to balance somewhat your rear spring rate to your front rates... I know there's a torsion bar stock. I've left it their but added coil springs also. It's actually not as ghetto as it sounds. It's been done on multiple different car builds including Porsches and VWs we used to do that on 944 rear ends, in order to beat the rules for club racing... it will be fine, just harder to get the rates right. You may want to ditch the torsion bar, and you will likely need to reinforce the top of the strut mount. They weren't designed to hold the load once you transfer the area on the chassis bearing the weight. your front coil spings will eat into your inner wheel clearance and require those flares though.... |
ZacB20 |
Jun 19 2012, 09:25 PM
the front "springs" are torsion bars the 911 stock ones are bigger "stiffer" than stock 4 cylider ones... you can upgrade from there to a stiffer spring rate. you want to balance somewhat your rear spring rate to your front rates... I know there's a torsion bar stock. I've left it their but added coil springs also. It's actually not as ghetto as it sounds. It's been done on multiple different car builds including Porsches and VWs we used to do that on 944 rear ends, in order to beat the rules for club racing... it will be fine, just harder to get the rates right. You may want to ditch the torsion bar, and you will likely need to reinforce the top of the strut mount. They weren't designed to hold the load once you transfer the area on the chassis bearing the weight. your front coil spings will eat into your inner wheel clearance and require those flares though.... Thanks for the tips. I plan to have my buddy build a chromoly tube chassis. And yea like I said, I'm getting a body kit... I want a wider wheel trac |
brant |
Jun 19 2012, 09:34 PM
you should check out this build thread
the car is local to me and the builder is a great guy, a real car nut... http://www.914world.com/bbs2/index.php?sho...c=50151&hl= |
Eric_Shea |
Jun 19 2012, 10:59 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
type47 |
Jun 20 2012, 06:44 AM
Thought someone would comment on transmission.... what tranny? Not sure 550 hp and 901 tranny are a good combo.....
ZacB20 |
Jun 20 2012, 09:55 AM
Thought someone would comment on transmission.... what tranny? Not sure 550 hp and 901 tranny are a good combo..... It is a 915, but still, unless someone will rebuild it for me with a lot taller gears, I'm already looking into a g50 or 930... Thanks for the concern! |
ZacB20 |
Jun 20 2012, 09:57 AM
What will my best option on 911 strut/ spindle combos be? I'm thinking stock from a pick n pull because after that motor and tranny, my wallet is gonna be crying.
Lo-Fi Version | Time is now: 10th June 2024 - 12:31 AM |
