partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,613 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
The top of the window and follow it back to the rear corner of the glass
Is there an adjustment to getting that corner of the glass to tip in a bit so that it seals better where the horizontal targa top seal and the vertical roll bar seal meet? |
obscurity |
Member ![]() ![]() Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States ![]() |
The top of the window and follow it back to the rear corner of the glass Is there an adjustment to getting that corner of the glass to tip in a bit so that it seals better where the horizontal targa top seal and the vertical roll bar seal meet? Perhaps someone else will chime in but if I recall there is a nut on the bottom of the door that will make this adjustment John |
reharvey |
Senior Member ![]() ![]() ![]() Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States ![]() |
The top of the window and follow it back to the rear corner of the glass Is there an adjustment to getting that corner of the glass to tip in a bit so that it seals better where the horizontal targa top seal and the vertical roll bar seal meet? The glass is adjustable in every direction you can think of. You'll need to remove the door pad to go at it. |
Lo-Fi Version | Time is now: 19th July 2025 - 06:56 AM |
