jrrhdmust |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 12-October 11 From: Alabama Member No.: 13,668 Region Association: None ![]() |
So I finally have the right side of the car repaired with panels welded in.
I ordered a new panel from restoration design that meets up with the engine, as well as a new battery tray. It looks like from the factory those are spot welded. Is everyone spot welding them, or completely welding? Thanks |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,590 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Spot weld it and move on.
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,757 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) Don't waste too much time on it. Plus it will make it easier to remove if you need to. I only tacked mine in with 4-5 and it holds fine.
jrrhdmust |
Thanks! (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 19th July 2025 - 02:58 AM |
