| pete-stevers |
Jun 27 2012, 01:01 PM
Shinee Side Up Prep and Paint ![]() ![]() ![]() ![]() Group: Members Posts: 2,671 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest
any ideas welcome
i am hoping to mount above the engine lid and below the deck..so it is kinda tight, brite is nice |
| a914622 |
Jun 27 2012, 10:45 PM
Member ![]() ![]() Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
I put a Volvo s70 in the back window of the vanagon. The wagons had the same angle on the glass as the vanagons. Glue it right on.
Not sure if it helps? They are super bright(reflects off stop signs half bolck away) and inside the glass no holes in the body. Search pics on the samba under a914622 jcl |
| aircooledtechguy |
Jun 28 2012, 08:54 AM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I would call Wolfsburg West (951.549.0525) and ask them if this lens will fit into the '67-'71 bus reverse light assembly (I believe they do but I am not 100% sure). If it does, those housings/assemblies are easy to get at a swap or wrecking yard and will look and work as stock. I may even have one here kicking around. Install a super bright LED bulb and you'll be GTG.
I don't know if it willl fit into that small space, but you could mount it to the deck lid like stock ones were. . . |
Lo-Fi Version | Time is now: 15th March 2026 - 10:32 AM |
