> twisted engine?, engine & transmission are rotated a bit to the driver's side
MarkS
post Jun 28 2012, 03:00 PM
Replacing my Monza muffler with something quieter and noticed one side of the exhaust was a good bit lower than the other. Once the exhaust was removed, it seems the whole engine + transmission is rotated a bit towards the driver's side.
Any clue as to why this would happen? Pics below. Thanks in advance.
MarkAttached Image Attached ImageAttached Image
Replies(1 - 19)
TargaToy
post Jun 28 2012, 03:04 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
Has your left transmission ear broken loose from the mount? Is it bolted into place without the bushing between the right ear and the bottom of the trunk?
SLITS
post Jun 28 2012, 03:05 PM
"This Utah shit is HARSH!"
Either your mounts are bad / damaged / ?? or the body is twisted.
jsayre914
post Jun 28 2012, 03:14 PM
Speed Up !!!
take a picture of the rear of the tranny looking up at the mount, you may even be missing some harware
also from the top of the engine does the tin line up on both sides or can you get your fingers in there. Scarry
(IMG:style_emoticons/default/blink.gif)
MarkS
post Jun 28 2012, 03:22 PM
ok, found it. see pics below. this does not look cheap.
what is the fix? Attached ImageAttached ImageAttached Image[attachmentid=319
574]Attached Image
jmill
post Jun 28 2012, 03:33 PM
Green Hornet
Looks like it's been fixed before. It's not as bad as you would think. Dr. Evil can hook you up with parts. I have two nose (or is it tail on a teener) cones hanging around my garage. I'm sure others closer to you have spares. I'd check the front engine mounts too. The rubber may be torn up.
rgalla9146
post Jun 28 2012, 03:36 PM
QUOTE(SLITS @ Jun 28 2012, 01:05 PM) *
Missing or loose left transmission mounting bolt ?
MarkS
post Jun 28 2012, 03:40 PM
QUOTE(jmill @ Jun 28 2012, 05:33 PM) *
It does look like it may have been welded before.
What does the fix involve? Replacing the nose/tail?
TheCabinetmaker
post Jun 28 2012, 03:50 PM
I drive my car everyday
Replace it. Has the car been in a wreck? That is usually what happens when it gets in hit the rear or from one side. Have two here with both sides snapped on impact.
jsayre914
post Jun 28 2012, 03:53 PM
Speed Up !!!
Easy fix, you will have it up and running in a day
No kidding, (IMG:style_emoticons/default/cheer.gif)
Bartlett 914
post Jun 28 2012, 03:54 PM
QUOTE(MarkS @ Jun 28 2012, 04:40 PM) *
Looks like the transmission has been neglected. It can be changed in the car but I would suggest sending it out or do a swap. I am guessing you are way overdue for an oil change.
MarkS
post Jun 28 2012, 03:57 PM
Has not been in a wreck as far as I know.
Ok, so I need to replace the tail cone. Where does on find one? Should I look for a used one? (note my "newbie" status)
Also, what else should I do while I'm back there? New rubber mounts? Anything else?
jsayre914
post Jun 28 2012, 04:04 PM
Speed Up !!!
QUOTE(MarkS @ Jun 28 2012, 05:57 PM) *
First post a WTB/ ad for the parts
then
send a PM to Dr. Evil
Mike is a way cool guy, and he has one for sure.
MarkS
post Jun 28 2012, 04:09 PM
ok, thank you.
Valy
post Jun 28 2012, 04:37 PM
Since the ear broke twice in the same place there are 2 possibilities:
1. bad welding the first time
2. there is some stress on that ear due to body deformation. Make sure this is not the case before you make the repair and brake it again.
MarkS
post Jun 28 2012, 04:47 PM
Got it, thanks.
jmill
post Jun 28 2012, 07:35 PM
Green Hornet
QUOTE(MarkS @ Jun 28 2012, 04:57 PM) *
Check your front engine mounts. I think they're torn up putting extra stress on the left ear.
G e o r g e
post Jun 28 2012, 07:49 PM
Dr
QUOTE(jmill @ Jun 28 2012, 06:35 PM) *
(IMG:style_emoticons/default/agree.gif) that was my first thought
underthetire
post Jun 28 2012, 09:19 PM
Think you should change both the motor mounts and trans mounts. You don't want to go through this twice if you can avoid it.
TargaToy
post Jun 28 2012, 09:25 PM
I'm amazed you were able to select all 5 gears.
- Lo-Fi Version Time is now: 31st July 2025 - 05:33 PM
