| DEC |
Jun 29 2012, 04:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 632 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany
Hi
I got my 916 Gearbox. (IMG:style_emoticons/default/piratenanner.gif) It was build by Martin, he has a thread in the member vendor section 915 to 916 The kit is awesome and Martin does an outstanding job. (IMG:style_emoticons/default/beerchug.gif) Thanks Martin Now it's time to modify the clutch actuation |
| phillstek |
Jun 29 2012, 04:29 AM
Member ![]() ![]() Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
Very nice work indeed. I see it also has the reverse light switch on the tail housing unlike the Wevo which doesn't.
| Cairo94507 |
Jun 29 2012, 06:21 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,665 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
(IMG:style_emoticons/default/drooley.gif) That is a very nice transaxle.
| ChrisFoley |
Jun 29 2012, 06:54 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,030 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
The mechanical speedo drive is a nice feature.
Accomodating an electronic speedo is a bit of a project. |
| Steve |
Jun 29 2012, 07:25 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,047 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Nice!!! Congratulations!!
Patrick Motor Sports makes the clutch adapter bracket. It reuses the stock 914 wheel and bracket. http://www.patrickmotorsports.com/part/1313/ http://www.patrickmotorsports.com/part/597/ That's what I am using with my 916 kit from Martin. I also went with the electronic speedo side plate from Wevo. It uses the factory speed sensor. http://wevo.com/Products/TransmissionProdu...nSideCovers.htm |
| 0396 |
Jun 29 2012, 08:37 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Congrats- Very cool , one day...
| DEC |
Jun 30 2012, 04:48 AM
Nice!!! Congratulations!! Patrick Motor Sports makes the clutch adapter bracket. It reuses the stock 914 wheel and bracket. http://www.patrickmotorsports.com/part/1313/ http://www.patrickmotorsports.com/part/597/ That's what I am using with my 916 kit from Martin. I also went with the electronic speedo side plate from Wevo. It uses the factory speed sensor. http://wevo.com/Products/TransmissionProdu...nSideCovers.htm Thanks for the links (IMG:style_emoticons/default/beerchug.gif) but my plan is to make a spezial solution for a special gearbox (IMG:style_emoticons/default/idea.gif) without using the OE parts. |
Lo-Fi Version | Time is now: 9th June 2026 - 01:19 PM |
