Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
been messing with the rear control-arms tonight (yes, I actually spend some time in the garage!)
How does the hub come out of the control-arm? Should I take it to a shop with a press or can I (IMG:style_emoticons/default/smash.gif) this myself? cheers, Jeroen |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
I bought a bearing tap and pounded it out! You will have to replace the Bearing anyway (IMG:style_emoticons/default/smash.gif)
Jeff |
vortrex |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None ![]() |
the right size pipe worked for me (well, actually the guy at the shop who pounded it out).
Jeffs9146 |
Yea, I put a pipe over the Bearing tap and pounded with a sledge hammer! (IMG:style_emoticons/default/smash.gif)
Jeff |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
A piece of pipe or a socket the right size to tap out the hub, then tap out the bearing from the trailing arm. I used a 3lb maul to hit it with cuz one side stuck in there pretty good. Spray the hell out of everything with PB Blaster or the Dutch Oil Release Spray.
Geoff |
Kerrys914 |
Dear, the parts I just sold paid for that part ;) ![]() ![]() ![]() Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 ![]() |
Did the old 4-5 lug conversion about 3 months ago. As everyone indicated (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) away!!!!
You won't be reusing it so beat the hell out of it. Make sure you have it up on SOLID stands. Cheers Kerry (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 13th June 2024 - 12:32 AM |
