> Engine fuel hose/Vacuum line kit?, Is there a complete kit available?
Jon H.
post Jun 30 2012, 12:40 PM
Hello' I am looking to buy a complete set of hoses/vacuum lines for my 2.0l engine. I know I can buy all the individual hose by the metre from Pelican but, is a there a complete, pre-cut set available?
Thanks'
Jon
Replies(1 - 5)
mstein95
post Jun 30 2012, 01:18 PM
Back when grey Levi's were the rage.
I believe auto atlanta sells a kit
Automobile Atlanta
Type in "914 vacuum kit" in the search field - several results
JawjaPorsche
post Jun 30 2012, 01:30 PM
Here is link:
http://www.autoatlanta.com/Porsche-Vacuum-...BAAVACKIT3.html
I purchased the kit for my 1.7 last fall.
Here is link for fuel line kit.
http://www.autoatlanta.com/Porsche-Fuel-Li...AA20100074.html
Jon H.
post Jun 30 2012, 02:09 PM
Thanks for the quick replies!
TheCabinetmaker
post Jun 30 2012, 02:12 PM
I drive my car everyday
I would caution you about using that cloth covered fuel hose. Its not compatible with ethanol fuels. It will breakdown the rubber inside, and leak thru the fabric hose. Use only hose meant for modern fuels. Goodyear 30R, or Cohline, or even napa now has a high pressure hose that is rated for use with any fuel. Use the proper FI hose clamps too. Not the serrated worm gear clamps with the holes in the band.
matt5596
post Jul 1 2012, 07:17 PM
QUOTE(JawjaPorsche @ Jun 30 2012, 03:30 PM) *
Does this kit include everything needed to replace the fuel lines in engine compartment? The description talks only about under fuel tank.
- Lo-Fi Version Time is now: 2nd November 2026 - 04:16 PM
