Jon H.
Jun 30 2012, 12:40 PM
Hello' I am looking to buy a complete set of hoses/vacuum lines for my 2.0l engine. I know I can buy all the individual hose by the metre from Pelican but, is a there a complete, pre-cut set available?
Thanks'
Jon
mstein95
Jun 30 2012, 01:18 PM
I believe auto atlanta sells a kit
Automobile AtlantaType in "914 vacuum kit" in the search field - several results
JawjaPorsche
Jun 30 2012, 01:30 PM
Jon H.
Jun 30 2012, 02:09 PM
Thanks for the quick replies!
TheCabinetmaker
Jun 30 2012, 02:12 PM
I would caution you about using that cloth covered fuel hose. Its not compatible with ethanol fuels. It will breakdown the rubber inside, and leak thru the fabric hose. Use only hose meant for modern fuels. Goodyear 30R, or Cohline, or even napa now has a high pressure hose that is rated for use with any fuel. Use the proper FI hose clamps too. Not the serrated worm gear clamps with the holes in the band.
matt5596
Jul 1 2012, 07:17 PM
QUOTE(JawjaPorsche @ Jun 30 2012, 03:30 PM)
Does this kit include everything needed to replace the fuel lines in engine compartment? The description talks only about under fuel tank.
