Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,807 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
The car is a 72. I am trying to figure out what some of the wires are for on the car to reuse for other purposes. The first is actually a round plug that sits in the access panel between the two seat. It has two yellow wires going to the plug. One of those wires runs forward on the tunnel. The second yellow wire goes? There is also a white wire to that same plug?
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
best I can do:
http://www.pelicanparts.com/914/parts/elec...lectric_71A.jpg http://www.pelicanparts.com/914/parts/elec...lectric_71b.jpg I can't see any component wth 2 yellows and a white..... |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
its not part of the seatbelt buzzer is it?
Attached image(s) ![]() |
Krieger |
I found the old seat belts. There is a plug coming off the two seat belt receivers that plugs into it. So now still the question where does the yellow and white wires go?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,234 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
its not part of the seatbelt buzzer is it? If i'm not mistaken, the '72 cars didn't have a seat belt buzzer ... (IMG:style_emoticons/default/idea.gif) PS: Pictures would help! (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Krieger |
I have a new computer and this may be too big.
Krieger |
Maybe too small?
Krieger |
Too big?
Attached thumbnail(s) ![]() |
Krieger |
Here is another one Im tackling. I removed the door buzzer switches and most of the wiring. I will not use them. Im left with this gray wire with a redish brown spiraling stripe coming from the ignition switch. It eventually, through the switches, ran to a plug with no relay on the fuse box....I think Can I just use shrink tubing over the end from the ig switch?
Krieger |
This is where there is another matching wire from door contacts. Hook up to wire dangling from ig switch? Or cut off at the fuse box and use the wire danging from ignition to power something else in future?
type47 |
I suggest you look for wiring colors in the later track current flow diagrams on pelican; they are the 74-> (there is a link in my signature). I think there are fewer differences in color; more similarities with your 72 so you "should" be able to find your items...
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,192 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Relay with a gray/red wire on the fuse panel looks to be a fog light relay. Are there also red/black, white/blue, and white/yellow wires?
The yellows and white does not look familiar, but I'm not very familiar with 72s, nor with the center tunnel wires. Are the wires a solid yellow and solid white? --DD |
Krieger |
Hey Dave, the relay only has one solid red and two of the gray/reds.
The yellow and whites are solid as best I can tell. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Yellow and white turns the red light on on the dash... "Fasten Seat Belt" when there's a butt in the passengers cushion.
cwpeden |
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada ![]() |
Yellow and white turns the red light on on the dash... "Fasten Seat Belt" when there's a butt in the passengers cushion. I agree, my 72 had sensor cushions with no lights or associated electronics? (IMG:style_emoticons/default/huh.gif) |
Krieger |
DOH! I have been looking at the wrong wiring diagram. I was not seeing the word "except" printed next to USA. I feel like a dummy. Its for seat belts.
Lo-Fi Version | Time is now: 2nd July 2025 - 07:32 PM |
