Late Model Window Regulator Coil Spring, Can someone post a picture? |
Eric_Shea |
Jul 1 2012, 09:52 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
There's something I'm missing on the late model window regulator and the coil spring (73 on). My coil springs are just sitting there and I'm fairly certain there's some sort of attachment that rides on that arm and hooks in the loop.
The factory manual is no hope, it just shows the front side. Anyone have a late model window regulator out so you can show me the backside and the coil spring attachment? (IMG:style_emoticons/default/beerchug.gif) |
McMark |
Jul 1 2012, 10:00 PM
I don't have a pic on hand. But I had a set of 912 mechanisms plated and the process ate the center portion that the spring clips into. (IMG:style_emoticons/default/yikes.gif) Can't say for sure this is the same situation/piece on the 914 door. But if you post a pic of what you've got, I might be able to help.
Eric_Shea |
Jul 1 2012, 10:17 PM
The center of the coil is fine. The outside has a loop on it. They're in the door now but I'll see if I can get a picture. They are facing the skin so... it might be hard to grasp.
sixnotfour |
Jul 1 2012, 10:43 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Attached image(s) |
Eric_Shea |
Jul 2 2012, 08:17 AM
Thanks... I think (IMG:style_emoticons/default/sad.gif)
veltror |
Jul 2 2012, 02:41 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
(IMG:style_emoticons/default/smile.gif) Finally I can be useful, I found a NOS winder sometime back so since my car is still in bits I could use this picture.
R Attached thumbnail(s) |
Eric_Shea |
Jul 2 2012, 04:57 PM
It appears as though that shiney bit is pot metal.
As per Mark's post. They did not survive the plating experience. |
SirAndy |
Jul 2 2012, 05:43 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It appears as though that shiney bit is pot metal. As per Mark's post. They did not survive the plating experience. That should be an easy fix ... (IMG:style_emoticons/default/welder.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 11:27 AM |
