Factory 914/6 oil tank, How is this thing mounted? |
Gint |
May 12 2003, 07:57 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Looks like I'm going to have to remove the tank to remove the sail panel and targa trim. It isn't painfully obvious how it's mounted. Any body know the details? And while we're at it, any gotchas when removing it?
Brad Roberts |
May 12 2003, 07:58 PM
The lower oil line fitting holds the bottom.
The two 13mm nuts bolt it to the inside panel. Remove the relay board if you havent. B |
Lawrence |
May 12 2003, 08:00 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
Yeah, unbolting it is easy. Consider replacing the grommets and oil filler gasket while you're in there.
R&R requires a contortionist. (IMG:style_emoticons/default/smile.gif) -Rusty |
Gint |
May 12 2003, 08:03 PM
QUOTE R&R requires a contortionist. What's new? Thanks guys |
ArtechnikA |
May 12 2003, 08:22 PM
...and be glad your car is squished on the right side, not the left like mine - i'm gonna hafta do bodywork so i can get the oil tank out so i can begin the bodywork ...
Gint |
May 12 2003, 08:51 PM
QUOTE ...and be glad your car is squished on the right side, not the left like mine Good point. Although I had to be very creative getting the wheel off the right side! |
mr914 |
May 13 2003, 11:12 AM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
I just pulled mine out last week. Sounds like Ginter and I are doing a similar rustoration.
A side note. You do have to take the oil filter spout off to get the tank out. Mine had a bunch of undercoating and dirt that made it a little difficult to get out. Discovered something. It appears that the oil tank was originally copper plated and then painted. Is this correct? |
Gint |
May 13 2003, 11:18 AM
Mine has some missing paint and shows copper or brass below. It's still in the car at this point. I have heard in the past that they are copper (I think). Someone will correct me if I'm wrong.
JWest |
May 13 2003, 12:06 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
The oil tank is steel, copper plated, then painted.
Gint |
May 13 2003, 01:23 PM
Thanks James
Don Wohlfarth |
May 13 2003, 03:15 PM
Member Group: Members Posts: 104 Joined: 8-January 03 From: Fairfax, VA Member No.: 117 |
Take your time. Years of acculated dirt and debris get packed around the tank and you'll swear someone is lying to you about the removal. (IMG:style_emoticons/default/wink.gif)
I cleaned the tank surface and found some small oil leaks. Made sure every thing was clean and used fiberglass cloth and resin to seal it. Damn thing was so tight was afraid to try anything else. 10-12 years later and no leaks. |
krk |
May 13 2003, 07:48 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
QUOTE(Don Wohlfarth @ May 13 2003, 01:15 PM) Take your time. Years of acculated dirt and debris get packed around the tank and you'll swear someone is lying to you about the removal. (IMG:style_emoticons/default/wink.gif) I cleaned the tank surface and found some small oil leaks. Made sure every thing was clean and used fiberglass cloth and resin to seal it. Damn thing was so tight was afraid to try anything else. 10-12 years later and no leaks. Don, 10-12 years? That's cool! (not too many things last that long unmaintained!) hm... have we seen pics of your /6? (subtle, eh?) (IMG:style_emoticons/default/mueba.gif) kim. |
Gint |
May 14 2003, 08:32 PM
Can comeone please tell me how to get this sonofabitch out? I've removed all appendages and have the tank out of all of the holes in the inner fenderwell (the pic is before attempt at removal). I can't get it more than a few inches aft.
Attached image(s) |
ArtechnikA |
May 14 2003, 08:49 PM
QUOTE(ginter @ May 14 2003, 06:32 PM) Can comeone please tell me how to get this sonofabitch out? have ya tried foul language ? i understand that's required in liberal quantities... IIRC it doesn't come 'aft' so much as 'down' - but i haven't done mine personally so i can't from firsthand experience... off to dinner and a Sneak Preview of The Matrix Unloaded... (probably our last night to play fior a while...) |
Gint |
May 14 2003, 08:52 PM
QUOTE have ya tried foul language ? i understand that's required in liberal quantities... IIRC it doesn't come 'aft' so much as 'down' - but i haven't done mine personally so i can't from firsthand experience... That's usually the first tool I reach for... I can't get it down due to the line on the outer side of the tank (the one that goes under the trailing arm and then inboard to the motor). And I don't have enough room to get a wrench in to get the line off. Enjoy your night off Rich. |
Porsche Rescue |
May 14 2003, 10:09 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
My memory says the line you are talking about comes off the bottom of the tank and goes over the trailing arm. It is pretty short (12-14"). Should just drop straight down with the tank. My problem was installing when I learned the hard way that I could not get a wrench in to tighten it. Had to pull the tank again and align the hose, tighten, then re-install tank.
Gint |
May 14 2003, 10:40 PM
Thank you Jim, That's the one. Problem is, I can't get a wrench on the small nut (on the line) or the large nut on the bottom of the tank. No clearance for the wrench up in there. And I can't get it low enough past the bottom ridge either.
Attached image(s) |
Gint |
May 14 2003, 10:58 PM
Brad?
Brad Roberts |
May 14 2003, 11:15 PM
Take another pic for me.. and back the camera out a little. I need to see that whole line. I normally leave that hose attached to the tank and disconnect it from the union for the short line running to the oil cooler. There should be a union that hangs in that 9146 specific "loop" welded to the frame rail.. it has a little rubber ring in it to keep from chaffing the rubber oil lines.
B |
Gint |
May 14 2003, 11:19 PM
Can't. The camera was on the ground as it is. That's the hose. It disconnected from the pipe and the union that goes in that loop your referring to. The line is only about 10" long total.
Lo-Fi Version | Time is now: 22nd May 2024 - 10:42 PM |
