wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
Got my rear calipers free finally by releasing the rear shock struck and dropping down the swing arm. This gave me more room and allowed me to get more leverage.
Solved that problem Next the rear disc, got one screw out , the other I had to drill off the head, now I am looking for a puller. I can't seem to budge it with traditional methods. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Got my rear calipers free finally by releasing the rear shock struck and dropping down the swing arm. This gave me more room and allowed me to get more leverage. Solved that problem Next the rear disc, got one screw out , the other I had to drill off the head, now I am looking for a puller. I can't seem to budge it with traditional methods. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) The disc is a close fit onto the hub, and rust will make them stick together. There should be two threaded holes in the disc which can be used for popping the disc off the hub using two 8mm bolts. You can use a torch to heat the hat portion of the disc and expand it so it comes off the hub more easily. |
wndsnd |
Got my rear calipers free finally by releasing the rear shock struck and dropping down the swing arm. This gave me more room and allowed me to get more leverage. Solved that problem Next the rear disc, got one screw out , the other I had to drill off the head, now I am looking for a puller. I can't seem to budge it with traditional methods. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) The disc is a close fit onto the hub, and rust will make them stick together. There should be two threaded holes in the disc which can be used for popping the disc off the hub using two 8mm bolts. You can use a torch to heat the hat portion of the disc and expand it so it comes off the hub more easily. Thanks Chris, but since I now only have one threaded hole, I am guessing it will bind. I will try again tonight. |
ChrisFoley |
wndsnd |
Thanks Chris, but since I now only have one threaded hole, I am guessing it will bind. I will try again tonight. I wasn't referring to the holes for the flathead screws. There are two other holes in the rotor for jacking screws. That is great news..... I read the manual about using the 8m bolts and it didn't make sense to me.. I thought the threads were in the hub, not the disc. |
wndsnd |
Thanks Chris, but since I now only have one threaded hole, I am guessing it will bind. I will try again tonight. I wasn't referring to the holes for the flathead screws. There are two other holes in the rotor for jacking screws. Got it, worked slick. Thanks Chris. |
Lo-Fi Version | Time is now: 13th July 2025 - 12:07 AM |
