What do I need to know about restoring my suspension?, need to get everything apart and ready for powerder coating |
Type 47 |
Jul 15 2012, 08:01 PM
Senior Member Group: Members Posts: 783 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
What needs to be pressed off? What bushings do I need to replace/purchase? what needs to be done to the trailing arms before they are sand blasted. How do I get the struts seperated from the contol arms? etc., etc.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1342404119.1.jpg) |
poorsche914 |
Jul 15 2012, 08:08 PM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
I plan on doing the same later next month. Hope to learn what all is involved. (IMG:style_emoticons/default/driving.gif) |
rhodyguy |
Jul 16 2012, 09:04 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
powdercoating is going to cook all the control arm rubber bushings, add $$$$. another option is using a rattle can paint called ZERO RUST (google it) which is what i used when i did my front suspension. it really holds up to the environment and is easy to touch up if needed. i think eric shea also uses, or did, on his rear control arm packages
k |
toolguy |
Jul 16 2012, 10:00 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
The bushings will come off pretty easily with liberal use of WD40. . wedge a small screwdriver between the joints and squirt the WD inside. . work the screwdriver around. . . it may be a waste of time because old rubber bushings have usually set up with a 'squish' on one side and you'll need new ones. .
The really hard part is getting the new ones compressed to insert them. . I made some aluminum bushings with bullet noses that fit inside the a arms with the taper outward. . then with the rubbers inside the outer holders, I pressed them on the arms using some dish soap for lube. the 'bullets gently expand the rubber and make a smooth transition onto the A Arms Can't send you a picture because I sold the adapters at a local swap meet The tie rod ends is a heat and hit deal, they are usually wedged on real tight. The ball joints should be no problem , the early struts are a pinch bolt, maybe some PB Blaster to speed up and make things easier. And if you're feeling adventurous, you can pull the steering rack apart and repack the grease. . not a big deal if you are careful and watch how it comes apart. Attached image(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:06 AM |
