Carrera916 I got your photos, 5 views of my carbs you asked for |
spare time toys |
Oct 22 2004, 08:35 AM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
I hope these will do. Hey Jake can you shed light on these. You seemed interested in them. Anyone else who knows about them or want to chime in feel free (IMG:style_emoticons/default/wavey.gif)
spare time toys |
Oct 22 2004, 08:40 AM
view 2
spare time toys |
Oct 22 2004, 08:41 AM
view 3
spare time toys |
Oct 22 2004, 08:42 AM
view 4
spare time toys |
Oct 22 2004, 08:43 AM
and view 5 the tin duct thing on the front of fan is coming off its a P/O thing.
spare time toys |
Oct 22 2004, 02:07 PM
Quick bump to be sure Carrera916 sees this.
Carrera916 |
Oct 22 2004, 03:11 PM
Member Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 |
Hey....
thanks for showing....yeah, it is a later Solex carb based on the texture of the body surface (carb body)....the ones I worked on were sand cast type for 4 cammers....however, the ones you have are also used in most 356...some use the Zeniths which I personally think it's piece a crap.... I can maybe see why Jake likes the manifolds....it looks like a beefy one that can withstand any BS going on in the engine compartment (IMG:style_emoticons/default/confused24.gif) ....and what I see and like the most, is the way it holds the crossbar linkage system, independently from the carbs...that's neat if you need to pull the carb fast out without having to mess around with the crossbar....neat... so Jake, what's got you all "woody" over the manifolds? i'm curious to know.... (IMG:style_emoticons/default/wink.gif) |
Brett W |
Oct 22 2004, 03:23 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
You want to part with those. I will trade you two sets of adapted Weber manifolds with different port configurations plus an acceptable amount of cash.
spare time toys |
Oct 22 2004, 05:38 PM
QUOTE(Brett W @ Oct 22 2004, 04:23 PM) You want to part with those. I will trade you two sets of adapted Weber manifolds with different port configurations plus an acceptable amount of cash. How does a Weber mount to the manifold? Or whats Weber adapted? Not sure if I want to part with them just yet cause then I would have to find carbs, manifolds,and linkage when I have it now. Im just not sure if this is going to be a headach carb set up like some have sugested. |
spare time toys |
Oct 23 2004, 07:52 AM
(IMG:style_emoticons/default/icon_bump.gif) one last time in the hope Jake will fill us in (IMG:style_emoticons/default/confused24.gif)
rhodyguy |
Oct 23 2004, 08:00 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
my guess is short runner length.
davep |
Oct 23 2004, 08:03 AM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Interestingly, a very early 914/4 came to the US with this type of set-up. It was not DOT certified so could not be licenced. So this particular design was around as early as 1969. Does anyone recall the details of the kit used for racing?
Brett W |
Oct 24 2004, 09:58 AM
I will modify the weber intakes to mount your Solex carbs so that it will be a direct swap.
Lo-Fi Version | Time is now: 8th June 2024 - 03:21 PM |
