Oil cooler add on, Who has found |
Porschef |
Jul 23 2012, 07:16 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
A kit that does the job, and includes a thermostat? I've done a bit of searching but haven't found one to work on a type 4 with a stat that opens in the 190* range....
Thanks |
jim_hoyland |
Jul 23 2012, 07:22 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Try the BAT web site ?
JStroud |
Jul 23 2012, 08:42 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
I couldn't find a "kit" when I added mine, I ended up buying the components and fittings and made my own kit. I used summit racing, Livermore performance, and aircooled.net. To buy my parts.
Good luck, hope this helps. Jeff |
Dave_Darling |
Jul 23 2012, 09:05 AM
I used a "sandwich plate" adaptor, cooler, and thermostat from Earl's. Not sure where I bought them, it was many years ago. I bought a fan and thermostat switch from Summit (switch didn't get here in time so it is not installed yet). I bought my hoses and fittings from a local hydraulic supply shop.
It took me quite a few trips there to get the lines and such correct. The "-10" lines do not bend very easily and have a large bend radius, so I wound up re-buying everything in "-8" to get everything to fit where I wanted. The fittings in the sandwich plate I used are 3/8" anyway, so those are the most restrictive part. I figured going down to 1/2" hose ("-8") wouldn't hurt things at all. --DD |
Dennis |
Jul 23 2012, 09:08 AM
Newbie Group: Members Posts: 28 Joined: 21-August 04 From: Sobieski, Wi. Member No.: 2,589 Region Association: Upper MidWest |
I couldn't find a "kit" when I added mine, I ended up buying the components and fittings and made my own kit. I used summit racing, Livermore performance, and aircooled.net. To buy my parts. Good luck, hope this helps. Jeff I went to Aircooled.net and got the Setrab single fan pack and went to Racerpartswholesale for a Mocal 180 degree thermostat but I believe they have 190 degree as well. Dennis |
ape914 |
Jul 23 2012, 10:39 AM
red locktite Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
I run no oil flow thermostat, however the electric fan is on a thermostat. No problems with heating up the oil. one problem I found with the sandwhich adaptor thermostat is the limited space for a quality filter. as filters get smaller they have less filtering capacity, and can be more restrictive, run in bypass mode.
i got a full flow HP 1 filter on a remote filter mount. Very large capacity filter. You can buy a seperate oil flow thermostat and run a remote filter with an remote filter adaptor plate in the stock filter location. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:44 PM |
