2056 with 9550 cam |
cgnj |
Jul 23 2012, 10:27 PM
Senior Member Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Well, I lost the free storage for my deal car and had to get off the dime.
Looking for info regarding 9550 cam and what static compression people are setting these up for. Jakes site says 8:1. Any cheaters out there? Have a line on an aircooled machine shop in Northern NJ, but he won't be able to do the balancing. Looking for one stop shopping near Philadelphia. Any help? Thanks in Advance, Carlos |
shuie |
Jul 23 2012, 10:43 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
Put it all in a box and send it to FAT Performance in Orange, CA.
Thestigz06 |
Jul 23 2012, 10:45 PM
Aspiring Jarhead Group: Members Posts: 238 Joined: 22-February 11 From: Temecula, CA Member No.: 12,749 Region Association: Southern California |
Put it all in a box and send it to FAT Performance in Orange, CA. (IMG:style_emoticons/default/agree.gif) Theyre the best |
cgnj |
Jul 23 2012, 10:52 PM
Put it all in a box and send it to FAT Performance in Orange, CA. (IMG:style_emoticons/default/agree.gif) Theyre the best Missed the part where I said I lost my storage? I know all the places on the left coat. Used them for my 2270 build. I need a place on the right coast. |
shuie |
Jul 23 2012, 11:32 PM
I guess you could ask Jake Raby (Air Cooled Technology) for help.
I'm on the Gulf Coast and I couldn't find anyone closer than FAT that I would want to deal with for engine work. |
Bleyseng |
Jul 24 2012, 03:25 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Well, I lost the free storage for my deal car and had to get off the dime. Looking for info regarding 9550 cam and what static compression people are setting these up for. Jakes site says 8:1. Any cheaters out there? Have a line on an aircooled machine shop in Northern NJ, but he won't be able to do the balancing. Looking for one stop shopping near Philadelphia. Any help? Thanks in Advance, Carlos I am running 9 to 1 CR and it works great! |
TheCabinetmaker |
Jul 24 2012, 04:23 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
9:1 here too. love it!
blitZ |
Jul 24 2012, 05:32 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
9:1 here also, with no problems.
rwilner |
Jul 24 2012, 06:04 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Chris Foley can hook you up for any machine shop work you need. He's in CT -- you could get to him and back in a day easily.
7275914911 |
Jul 24 2012, 06:11 AM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
+4 on 9:1
shuie |
Jul 24 2012, 07:11 AM
Porschef |
Jul 24 2012, 09:39 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
+1. 2056 w 9550. Ljet, 9:1
(IMG:style_emoticons/default/beerchug.gif) Idle is my only slight issue And go see Chris. Low key and very knowledgeable. |
cgnj |
Jul 24 2012, 09:47 AM
4 hours up, 4 back to CFR. Plus I'd be looking at impulse buying while at the shop. I did email Chris, site doesn't actually mention machine shop services.
Anyone ever use this place? http://www.pwr-tech.com/service_maintenance.html I seem to recall Evil Ed either working there or using them for his cis/turboed motor. Carlos |
ape914 |
Jul 24 2012, 09:58 AM
red locktite Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
I guess you could ask Jake Raby (Air Cooled Technology) for help. I'm on the Gulf Coast and I couldn't find anyone closer than FAT that I would want to deal with for engine work. jake will be no help if you deviate from his 8:1 he does not like his instructions questioned. however go ahead and post on his site if you want to be ignored or belittled. he dont post here anymore. the compression ratio should be picked by an experienced engine builder. timing, valves, combustion chamber shape, fuel, induction system all play a role in determining the max compression ratio allowed. Compression ratio is not only a function of the cam, but of many things |
Valy |
Jul 24 2012, 10:59 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
The 9550 is basically the webcam #73 with 5 degrees more on the exhaust.
You can run that cam at 9:1 on premium fuel. You should go a bit lower (8.5:1) if the octane is lower. You can also go higher with dished pistons. In any case, higher compression = heat. Don't expect too much improvement from higher compression. You're looking at 1-2 hp max. I plan to have 8.5:1 compression on my 2056. |
gothspeed |
Jul 27 2012, 03:51 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
The 9550 is basically the webcam #73 with 5 degrees more on the exhaust. You can run that cam at 9:1 on premium fuel. You should go a bit lower (8.5:1) if the octane is lower. You can also go higher with dished pistons. In any case, higher compression = heat. Don't expect too much improvement from higher compression. You're looking at 1-2 hp max. I plan to have 8.5:1 compression on my 2056. I have 8.5:1 compression on my fresh 2056cc w dual 44IDFs. It will be a daily driver so I did not want to go any higher (hot stop and go traffic at times) on the compression. What kind of RWHP do you guys see on a 2056cc, 8.5:1, with a 9550 D-jet? I know quite a few guys run this combo. (IMG:style_emoticons/default/smile.gif) |
Al Meredith |
Jul 27 2012, 05:43 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I have a 2056 that I built with Raby parts. I think I calculated 9.5. I run Premium , No problem. Remember carbs run a little richer ,hence, 9.5 should be OK.
EdwardBlume |
Jul 27 2012, 05:54 PM
What's the HP?
Al Meredith |
Jul 29 2012, 06:37 PM
I'm looking at the Dyno chart....Max Torque 125.2 at the rear wheels and Max HP is 106.6 RWHP. Mine is in a 912E . Over 110 Torque from 3000 RPM to 5600 RPM and over 100 HP at the wheels from 4400 RPM to 5900 rpm. That was with an 009 and 40MM Webers. I now have a Mallory and 44 MM webers. Look at Jakes website and see what he says the engine get on an engine DYNO. It is 120 HP and 130 FtLbs. The torque is the thing that makes it fun to drive and remember the 912E probably weighs at least 500 /700 LBs more than a 914.
Lo-Fi Version | Time is now: 9th June 2024 - 06:44 PM |
