Air Mixture Pipes to Air Intake |
kbrunk1 |
Jul 29 2012, 02:59 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
TheCabinetmaker |
Jul 29 2012, 03:24 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Probably should change all hoses. air, vacuum, and fuel after, 27 years.
Dave_Darling |
Jul 29 2012, 04:54 PM
I have seen the big fat hoses called "intake runner boots". To replace them, you have to pull the intake runner pipes off of the head and the manifold. They can leak, and after 20+ years they probably are leaking. They are far from the only possible leak, though.
--DD |
ape914 |
Jul 29 2012, 06:49 PM
red locktite Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
they may not leak at all, no sense pulling them and causing them to leak if they are ok. To pull them you end up redoing the gaskets on the heads too. Try to fire her up with the intake boots you have and see if she leaks or not. If you do have a leak, you could first try adding hose clamps, and/or tightening the head -mainfold nuts if you find leaks on the head end of the pipes.
don't waste time and money fixing a problem that may not even exist. i have run 20+ year old intake boots with no leaks what so ever, On others that were much newer I had to tighten hose clamps a bit, and that usually seals them off for me. chances are good you will be fine with what you have. |
Lo-Fi Version | Time is now: 10th June 2024 - 10:16 AM |
