Milling Turbo Valve Covers, Sixer Question |
t collins |
Aug 2 2012, 04:49 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
I'm ready to mill my turbo valve covers and was wondering should I mill the ribs down from end to end or just the area around the suspension console ears (IMG:style_emoticons/default/idea.gif) Does anyone think it makes any differance one way or the other? (IMG:style_emoticons/default/confused24.gif)
Thanks, Tom |
jtf914 |
Aug 2 2012, 05:32 PM
Member Group: Members Posts: 428 Joined: 31-December 02 From: Burlington, CT Member No.: 58 Region Association: North East States |
I milled them from end to end. It would probably work to only mill them around the suspension ears.
mepstein |
Aug 2 2012, 05:47 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I had the whole length milled down.
toolguy |
Aug 2 2012, 05:54 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
I pulled all the studs out and used allen socket head bolts instead. It really makes life a lot easier and you can keep all the fins on the covers. . makes them less susceptible to warping.
mepstein |
Aug 2 2012, 05:55 PM
toolguy |
Aug 2 2012, 06:08 PM
QUOTE(toolguy @ Aug 2 2012, 07:54 PM) *
I pulled all the studs out and used allen socket head bolts instead. It really makes life a lot easier and you can keep all the fins on the covers. . makes them less susceptible to warping. But more chance of stripping out the threads from the alum heads. Liquid Teflon thread sealer is your friend. . |
RiqueMar |
Aug 2 2012, 06:32 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Does it make it less susceptible to warping? Sure. If you're that concerned about warping your valve covers, then by all means only cut down the corresponding section.
Personally, when I had my 2.9, I didn't think it was that big of deal, and I took a 'form over function' approach. I also happen to think it looks better.... Even though it hangs on the bottom of the engine and almost no one will see it. (IMG:style_emoticons/default/wink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1296834901.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1296834901.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1296937479.1.jpg) |
t collins |
Aug 2 2012, 08:14 PM
Does it make it less susceptible to warping? Sure. If you're that concerned about warping your valve covers, then by all means only cut down the corresponding section. Personally, when I had my 2.9, I didn't think it was that big of deal, and I took a 'form over function' approach. I also happen to think it looks better.... Even though it hangs on the bottom of the engine and almost no one will see it. (IMG:style_emoticons/default/wink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1296834901.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1296834901.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1296937479.1.jpg) I tend to agree, end to end it is. Thanks, |
Krieger |
Aug 2 2012, 08:19 PM
Advanced Member Group: Members Posts: 4,728 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I did just what was necessary. I figured it would be beneficial to leave as much surface area for cooling. It is the exhaust valve cover...
scotty b |
Aug 2 2012, 08:29 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I like them done all the way. Only doing the small section necessary makes it look like a mod, whereas milling it all the way looks stock IMHO. I really doubt the small amount being taken off will affect colling at all (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 9th June 2024 - 11:21 PM |
