Air hose routing question '73 2.0 |
pbob42 |
Aug 3 2012, 10:03 AM
Newbie Group: Members Posts: 46 Joined: 6-June 12 From: san diego Member No.: 14,531 Region Association: None |
Getting my 2.0 ready for the road. Had been non-oped since '93. Put the air cleaner on (had been off to the side till now) and I have an extra 5/8" air hose with nothing to connect to. It comes off the top of the engine right in front of the computer. Any direction would be appreciated.
Madswede |
Aug 3 2012, 12:48 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
I think there's a diagram available somewhere ... try pelican parts website.
TheCabinetmaker |
Aug 3 2012, 01:29 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Top of the engine is a little vague. Is it coming from the fan shroud or the black engine tin? A picture is worth a 1000 words.
Dave_Darling |
Aug 3 2012, 03:13 PM
Pelican has diagrams which should help. Jeff Bowlsby also has diagrams on his pages. And there may be some under the "914 info" link at the top of this and every 914world page.
--DD |
Krieger |
Aug 3 2012, 06:18 PM
Advanced Member Group: Members Posts: 4,726 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Maybe the charcoal canister? Some years it was mounted to the battery tray
poorsche914 |
Aug 3 2012, 07:36 PM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
From the Pelican site:
(IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-10419-1344044201.1.jpg) (IMG:style_emoticons/default/driving.gif) |
pbob42 |
Aug 4 2012, 07:13 AM
thanks for the schematic. I am thinking the canister which is not there anymore. I will get a pic up here soon.
pbob42 |
Aug 4 2012, 12:09 PM
this is the one. Anyone know where it goes?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i415.photobucket.com-14531-1344103771.1.jpg) |
Dave_Darling |
Aug 4 2012, 01:06 PM
To the charcoal canister, eventually. In cars up through early 74 (including your 73) the canister should be above the fuel tank. So the line pictured would go across the engine to one of the plastic lines in the left-front corner of the engine bay. From there, it goes up front under the driver's rocker panel to the canister. Another line comes back through the rocker panel and gets hooked to the air cleaner.
--DD |
pbob42 |
Aug 4 2012, 02:37 PM
The two above my hand run back and forth across the motor through plastic tubes and tie into the air cleaner. The one below my finger comes out of that fitting on the engine/shroud and goes . . . .
pbob42 |
Aug 4 2012, 02:39 PM
well - let me see if there is anything open in the front left corner before I criticize your input. I did notice your 7,000 resonses compared to my 20.
pbob42 |
Aug 4 2012, 03:50 PM
I looked and the cannister hoses appear to be the two above my hand. It is the lower hose in the picture that I am concerned with.
Dave_Darling |
Aug 4 2012, 04:37 PM
If there is already a hose from the fan shroud or from the engine tin to the hoses to the charcoal canister, then this one is an extra and can be left unhooked. If it is open through to the inside, you might want to plug it just to keep the cooling air inside where it belongs.
If neither of those two hoses goes to the fan shroud or to the engine tin, then it is not hooked up correctly. (BTW, number of posts does not equal knowledge. I've been wrong before and will be so again, so have people with 10,000+ posts.) --DD |
Lo-Fi Version | Time is now: 8th June 2024 - 12:05 AM |
