Transmission, can't find gears |
minnesota loon |
Aug 6 2012, 08:42 AM
Member Group: Members Posts: 111 Joined: 30-September 07 From: white bear lake mn. Member No.: 8,173 |
Transmission seems to be out of sync. Sometimes goes into 1st 2nd 3rd but then shifts back to 2nd instead of 4th. Sometimes can't get it into 1st but have 2nd 3rd and 4th. clutch issue? trans issue? All gears work when in gear. Getting there is the question. 76 914 5 speed.
mrholland2 |
Aug 6 2012, 09:00 AM
Senior Member Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Is the shifter lever sloppy? IF so, then some of the plastic bushings along the shift rod are bad. The one that killed me was the one at the transmission mounted shifter "console". After you check and replace those (there are instructions and parts available through Pelican), then you need to adjust the shifter, which is pretty easy. I believe those instructions are on Pelican too. The adjustment is one of those things, that if you read the directions, you can't really break. Sean Transmission seems to be out of sync. Sometimes goes into 1st 2nd 3rd but then shifts back to 2nd instead of 4th. Sometimes can't get it into 1st but have 2nd 3rd and 4th. clutch issue? trans issue? All gears work when in gear. Getting there is the question. 76 914 5 speed. |
JawjaPorsche |
Aug 6 2012, 09:19 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Here is the link to the shift linkage kit:
http://www.pelicanparts.com/cgi-bin/smart/...76%29%2C%20Each Good Luck. This really makes a difference in your shifting. |
Dave_Darling |
Aug 6 2012, 02:48 PM
And descriptions and pics of where they go, plus more info on vague shifting:
http://www.pelicanparts.com/techarticles/9...ift_improve.htm --DD |
Dr Evil |
Aug 6 2012, 03:56 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/agree.gif) shift bushings. Check the U joint as well.
minnesota loon |
Aug 8 2012, 04:43 AM
thanks to all. I will check it out.
iamchappy |
Aug 8 2012, 07:54 AM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I have found many times the Allen head cone screw on the shift rod coupler by the firewall when loose can cause this to happen......
messix |
Aug 8 2012, 01:53 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
I have found many times the Allen head cone screw on the shift rod coupler by the firewall when loose can cause this to happen...... (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 06:52 PM |
