White smoke out the carb, Can't let the magic smoke escape |
bandjoey |
Aug 6 2012, 03:57 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
First try to start 2.0 carbs
Tries to start but white-blue smoke from cyl 3 through carb with POP. immediately shut it off before it started. Valve adjustment gone wrong on that cyl? Carb setting wrong (static setting via Dellorto book) ? Timing not moved since it was a running motor. What's the order of things to check? (IMG:style_emoticons/default/smash.gif) |
914Mels |
Aug 6 2012, 04:02 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Are you missing any hardware that might be holding the intake valve open on #3? A lean miss fire will have you popping up the carb also. What carb set up?
Dave_Darling |
Aug 6 2012, 06:08 PM
Plug wires in the right place?
--DD |
VaccaRabite |
Aug 6 2012, 09:19 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Dizzy 180 out, or your plug wires are 180 off. Give it enough fuel and you will blow pretty wild fireballs out the top of your carbs. BTDT.
Zach |
rick 918-S |
Aug 6 2012, 09:49 PM
Hey nice rack! -Celette Group: Members Posts: 20,473 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
If you didn't move the dizzy that's not the issue. Wires on in the wrong sequence, valve adjustment, burnt valve, sticking valve, valve seat failing.
Lo-Fi Version | Time is now: 1st June 2024 - 08:54 AM |
