Would this work for Mid Engine setup?, 1997 Chevrolet Corvette C5 Manual 6-Speed Transmission & 3.42 LSD Differential |
falconfp2001 |
Aug 8 2012, 01:56 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I was eyeballing this and just wondering how possible is this Transmission for a mid engine setup?
http://www.ebay.com/itm/ws/eBayISAPI.dll?V...B:WNARL:US:1120 |
6freak |
Aug 8 2012, 02:14 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
if ya got the $$$ anything will fit
(IMG:style_emoticons/default/smile.gif) |
seanery |
Aug 8 2012, 02:41 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
**simplified version**
C5s and C6s are transaxle setups. As long as there is room and you can mate the engine with the transaxle you're probably good to go. I'm actually doing legwork to figure out how to do a C5 rear end and transaxle in my '50 GMC truck behind a '64 Buick 401. |
bill pierce |
Aug 8 2012, 02:50 PM
Newbie Group: Members Posts: 16 Joined: 20-December 09 From: Rockford WA Member No.: 11,155 Region Association: None |
Looks pretty nice but, I think it would be too long. Ask the guy for dimensions.
rktmn247 |
Aug 8 2012, 03:14 PM
Irish Green with GT envy! Group: Members Posts: 347 Joined: 18-August 05 From: Mililani, HI Member No.: 4,612 Region Association: None |
Should there also be a bell housing? If so, It looks like axles would be way to far back.
ThePaintedMan |
Aug 8 2012, 03:21 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Should there also be a bell housing? If so, It looks like axles would be way to far back. No, the C5 and up Vettes use a torque tube that houses the driveshaft and bolts between engine and transaxle. I think there are adapters to bolt the engine directly to the transaxle, but I would assume that this would put everything way far back. You would probably end up cutting the rear firewall and moving it forward to fit. Not to mention that transaxle is really beefy and heavy. Doubt it would be worth the trouble. |
andys |
Aug 8 2012, 03:24 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
A mid-engine transaxle normally has the gear case aft of the differential. I the case of the Vette, the gear case is forward of the differential. This configuration is usually not suitable for a true mid-engine layout, though there's at least one case I know of where it has been done, but the car had to be stretched between the driver and the rear wheels.
Andys |
Dave_Darling |
Aug 8 2012, 03:43 PM
Sounds like what they did with the later 908 transmissions, to move the rear wheels further back in the chassis. They put the diff at the tail end of the box.
--DD |
matthepcat |
Aug 8 2012, 04:28 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
You would probably have better luck making a 924 turbo snail trans-axle work:
http://www.ebay.com/itm/1979-Porsche-924-T...n-/130453416671 I have a buddy with one sitting in his garage..probably let it go very cheap. |
rktmn247 |
Aug 9 2012, 12:15 AM
Should there also be a bell housing? If so, It looks like axles would be way to far back. No, the C5 and up Vettes use a torque tube that houses the driveshaft and bolts between engine and transaxle. I think there are adapters to bolt the engine directly to the transaxle, but I would assume that this would put everything way far back. You would probably end up cutting the rear firewall and moving it forward to fit. Not to mention that transaxle is really beefy and heavy. Doubt it would be worth the trouble. I know they use a torque tube and assumed there is a housing attached on the block for the clutch and pressure plate that would have to be connected back up to the transaxle, minus the torque tube, thus increasing the length beyond what the original poster had shown in his link. http://www.ebay.com/itm/1997-Chevrolet-Cor...#ht_2460wt_1218 |
bulitt |
Aug 9 2012, 06:55 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Too long. Unless the engine sat directly above the trans and you used a transfer case in the back between engine and trans. This arrangement used on various ferrari's such as the 512bbi but a boxer engine also used to reduce the height of the whole package.
rick 918-S |
Aug 9 2012, 08:49 AM
Hey nice rack! -Celette Group: Members Posts: 20,492 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Axles would be waaaaay too far back on both those units.
Katmanken |
Aug 9 2012, 04:15 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Oh cmon guys, easy fix.
Make it a front midships engine and run whatever driveshaft is required- or not. Might have to cut the dash, front trunk, and tranny tunnel a bit to fit the engine, and rear bulkhead to pass the tranny, but could work. Quick 2000 hours of work and your done! |
zymurgist |
Aug 9 2012, 04:20 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Oh cmon guys, easy fix. Make it a front midships engine and run whatever drivehsaft is required- or not. Might have to cut the dash, front trunk, and tranny tunnel a bit to fit the engine, and rear bulkhead to pass the tranny, but could work. Quick 2000 hours of work and your done! Or just buy a Corvette. (IMG:style_emoticons/default/stirthepot.gif) |
SirAndy |
Aug 9 2012, 04:35 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It would seem this is way too much work for no real added benefit.
(IMG:style_emoticons/default/idea.gif) |
falconfp2001 |
Aug 9 2012, 04:50 PM
I was thinking more of a 904 project for this. Or just use a Suby block and trans
Cap'n Krusty |
Aug 9 2012, 05:33 PM
You would probably have better luck making a 924 turbo snail trans-axle work: http://www.ebay.com/itm/1979-Porsche-924-T...n-/130453416671 I have a buddy with one sitting in his garage..probably let it go very cheap. Those trannies are among the most fragile units Porsche ever made. No parts available, even then, and when they failed back in the day, Porsche simply sold you another tranny at a steeply discounted price. Dave Aase was selling them for about 500 bucks, brand new. The Cap'n |
matthepcat |
Aug 10 2012, 09:09 AM
I actually think it's an Audi designed trans and I would put $ on it being more robust than a 901. Taller gears as well, which would work well for a higher torque application...but your correct...impossible to find parts.
Lo-Fi Version | Time is now: 8th June 2024 - 12:57 PM |
