| ruddyboys |
Oct 23 2004, 12:36 PM
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 595 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I tried replacing the O-rings 3 times, and still a leak. After running the car for about 10 min smpke starts to bellow out of the engine compartment. Problem I have old heads that have smaller push rid tubes and I am not about to send them out to be bored and buy new tubes. Would there be a problem with cleaning the area real good and using some kind of high temp silicon or such around the outside of the tubes and heads to stop the leak.
| Rich Bontempi |
Oct 23 2004, 12:42 PM
914 Road Racer ![]() ![]() Group: Members Posts: 167 Joined: 5-February 03 From: Redwood City Ca. 94063 Member No.: 239 Region Association: Northern California |
We have some of the correct push rod tube o-rings for the early 1.7's. Is that what you need to fix this problem?
| ruddyboys |
Oct 23 2004, 01:13 PM
Rich, I tried the right rings and it still leaks, something must be out of round.
| Joe Ricard |
Oct 23 2004, 06:21 PM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Well, I know what a pain this is. here is what I did and it seamed to work pretty good. Are you leaking at the case or head? After reading it seems like the head side???
Yes, Cleaning REALLY good with scotch bright pad or burnishing wheel on a dremel gets all the crap out. the sealing surface must be really smooth. the groove in the tube must be round and clean too. Go to home center and get white plumbers paste. Put a little on each O-ring. Tubes should slide right in (maybe a little shove). if ya gots to bang them in somethings wrong and the o-ring is rolling or getting cut. Found out the hard way about different size tubes for early 1.7L motors. |
Lo-Fi Version | Time is now: 15th April 2026 - 11:10 AM |
