Thestigz06 |
Aspiring Jarhead ![]() ![]() Group: Members Posts: 238 Joined: 22-February 11 From: Temecula, CA Member No.: 12,749 Region Association: Southern California ![]() |
Is it cool for it to be producing that much power?
If not, what could cause it? (IMG:style_emoticons/default/confused24.gif) It should also be said that my car has an intermittent problem of not making enough while driving which results in working very hard to get to 4000RPM and popping. While all of this goes on the generator light is slightly glowing and as i turn off the lights car runs better slightly better. If i let it sit for maybe 30 mins, i fire up and she runs fine, lights on and all. cant seem to figure it out. (IMG:style_emoticons/default/headbang.gif) |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
I think you're just fine!
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
13.6v is normal.
For starters clean all your grounds. |
Thestigz06 |
thanks for the response guys. il look deeper into the electrical! (IMG:style_emoticons/default/biggrin.gif)
Thestigz06 |
well, dug into it more today and did more testing. When the headlights with fogs are on its producing 12.6 volts, is this still normal?
Also, could the symptoms im experiencing be due to failing points/condenser? |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
Very likely on both counts.
Thestigz06 |
Very likely on both counts. meaning alt is fine and i just need to get off my a$$ and go buy another EI module? (IMG:style_emoticons/default/biggrin.gif) |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
The alternator/regulator is producing the same voltage all the time, but when you have a constant draw, ie the lights on, the battery will read lower. . battery floating voltage and alternator output are 2 different but related things. .
Your readings are normal |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Where are you measuring 12.6V? Across the battery?
The points/condenser could have to do with the lack of power but as long as your engine is running greater than about 1500-2000 RPM, the alternator should be producing 13V or greater as measured on your battery. The 2 are not related. Is the alternator belt tight? |
Thestigz06 |
Where are you measuring 12.6V? Across the battery? The points/condenser could have to do with the lack of power but as long as your engine is running greater than about 1500-2000 RPM, the alternator should be producing 13V or greater as measured on your battery. The 2 are not related. Is the alternator belt tight? i am measuring that across my battery. and the belt is not by any means loose. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Did you ever set your dwell? If not you can come by here and set it.
Thestigz06 |
Lo-Fi Version | Time is now: 10th June 2024 - 10:40 AM |
