2056 w 9550 cam, This time it's fuel consumption |
Porschef |
Aug 13 2012, 01:11 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
If you've got this arrangement, what are you getting for MPG's? Curious to see how you do.
Thanks. |
76-914 |
Aug 13 2012, 01:16 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
At 52 hours TT on engine with passenger; 80-90 mph hiway and 120 miles city driving. Total miles 996 miles. Got 37 mpg.
vw505 |
Aug 13 2012, 02:44 PM
Member Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None |
Is that with carbs or F/I ?
Porschef |
Aug 13 2012, 03:25 PM
Ljet. She ran great this past weekend, 400 miles each way. I'm just not thrilled with my uh, fuel economy.... (IMG:style_emoticons/default/hissyfit.gif)
37 mpg is incredible! |
hcdmueller |
Aug 13 2012, 03:31 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
Last summer I was getting somewhere in the low 30's at 85ish on the autobahn. The Germans put ethanol in their fuel now so it could be better. I am running D-Jet and have the mps adjusted to run pretty close to 14:1 at cruising speeds.
TheCabinetmaker |
Aug 13 2012, 03:34 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
D-jet. I'm getting 25 in town and around 32 highway. That is, when I can keep my foot out of it.
Valy |
Aug 13 2012, 04:32 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Don't expect better fuel economy than stock.
After all, more power=more fuel. |
euro911 |
Aug 13 2012, 05:01 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I have to fix my ODO and the the A/F dialed in so I can find out ... (IMG:style_emoticons/default/dry.gif)
Porschef |
Aug 13 2012, 05:30 PM
Well after the 800 mile weekend excursion, I was getting 23 mpg on the highway....kinda low in my estimation. At 4 bucks a pop for a gallon of 93, it adds up.
It's still a blast to drive, although I really need to get an AFM installed. |
r_towle |
Aug 13 2012, 06:39 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
sounds like it running to rich.
lotus_65 |
Aug 13 2012, 07:08 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
I'm running a 9580/w carbs, and my mpg's suck!
(IMG:style_emoticons/default/sad.gif) |
euro911 |
Aug 14 2012, 01:47 AM
Mine has a 9580 as well (IMG:style_emoticons/default/sad.gif)
Hoping the Carb Clinic on the 25th. helps to get it dialed in. Ordering 32mm venturis and some additional sets of main jets today. I'll report back. |
rwilner |
Aug 14 2012, 07:28 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Be careful if you lean it out at cruise to watch your head temperatures.
I don't have that combo, but I get my coolest temperatures around 13.5:1 at cruise, which yields around 28-30 mpg highway. I could go leaner and get better fuel economy but it's worth it to me to keep the engine cooler / last longer. If this was my only car I might experiment with a leaner cruise, but since it's the "fun car," this compromise is ok. |
wndsrfr |
Aug 14 2012, 07:09 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
" At 4 bucks a pop for a gallon of 93, it adds up. "
I'm running my 2316 with Raby 9560 cam, SDS injection & ignition & A/F/KA/S/Z gearing and can't seem to do better than 8mpg at DE's. At over $8.00 per gallon for 100 unleaded you're right it adds up--like a dollar a mile! And averaging about 60 works out to a dollar a minute.....definitely worth it! (IMG:style_emoticons/default/driving.gif) |
lotus_65 |
Aug 15 2012, 06:59 AM
Mine has a 9580 as well (IMG:style_emoticons/default/sad.gif) Hoping the Carb Clinic on the 25th. helps to get it dialed in. Ordering 32mm venturis and some additional sets of main jets today. I'll report back. Let me know how it works out. I have a narrow band o2 sensor, but it's useless. I'd invest in a wide-band (I am now) first and maybe a couple cht's (1-per side). Good luck! |
euro911 |
Aug 15 2012, 09:57 AM
Valy |
Aug 15 2012, 10:17 AM
If you've got this arrangement, what are you getting for MPG's? Curious to see how you do. I'm not hep to all of Raby's cams. Is the 9550 a carb cam, or an FI [compatible] cam?It's the famous Webcam #73 + 5deg on exhaust to help keep heads temp down. It's good for both stock FI and carbs, although you can use a cam with more overlap with the carbs. |
Lo-Fi Version | Time is now: 10th June 2024 - 03:23 AM |
