> points replacement options, a whole bunch of questions actually
brant
post Oct 24 2004, 09:19 AM
This is all for an early 911 motor with and ancient 1967- 2 piece points distributor.
I was intending to run a pertronix ignitor points replacemnt in it, but found out last night that it doesn't fit.....
so now I'm re-educating and re-shopping...
I run a crane in a different car and see that they do make a model to fit this dinasaur....
but my first question:
-Does an inline resistor prior to a coil, ultimately hurt the strength of the spark put out from the coil?
next question: I'm running an MSD box and their blaster coil, but want to replace the points...
-Does MSD make a points replacement now?
anybody know what other racers are using to replace points... specifically other racers with these ancient/small 2.0/6 vintage motors?
tia
brant
Replies(1 - 6)
Joe Bob
post Oct 24 2004, 09:35 AM
Check with Summit racing.....Crane optical units that repalce the points will work with most CDI boxes. BTW....you MAY need a tach adapter for the stock P-car tach. I went with an aftermarket tach on Frank and it workied withOUT the adapater.
Cap'n Krusty
post Oct 24 2004, 10:46 AM
Cap'n Krusty
I run a Crane Allison XR 700on my '65 911, and like it alot. I don't use a conventional Pcar CDI, just the Crane box, and have no more plug fouling problems ... Price is right. The Cap'n
ein 6er
post Oct 24 2004, 11:27 AM
brant,
i'm been running the crane xr 700 on the '67 2.0 in my 914 for about 2 years now with no problems with it. i'm useing the stock cdi to trigger the crane box and i didn't need a tach adapter.
if you use the right shutter wheel, you don't need to remove the points mounting post .......... like i did. (IMG:style_emoticons/default/headbang.gif)
brant
post Oct 25 2004, 09:02 AM
thanks fellas...
I'm fairly ignorant, but in theory what do you guys know about the thought I had regarding the resistor..(yes really a different question)
looks like I'll probably go with the crane agian then.
brant
SLITS
post Oct 25 2004, 09:20 AM
"This Utah shit is HARSH!"
Ran the Crane Allison on the race cars without a resistor and came up with two problems:
1. The spark was so "hot" it disintegerated the cap center electrode, but the spark would still jump from the cap to the rotor (IMG:style_emoticons/default/biggrin.gif)
2. The spark was so brilliant, it would trigger the LED (IMG:style_emoticons/default/smoke.gif) or was it the spark jumping around inside causing the misfire?
Yea, I put the resistor in line to drop the voltage to the coil to 9V. No problems after that and no fouled plugs.
brant
post Oct 25 2004, 09:26 AM
ohh...
good input, I hadn't even considered the too much power idea..
brant
- Lo-Fi Version Time is now: 12th November 2026 - 06:44 PM
