Thermo Time Switch 1973 1.7L |
JohnWayne |
Aug 19 2012, 04:00 PM
Newbie Group: Members Posts: 23 Joined: 18-July 12 From: Colorado Springs,CO Member No.: 14,691 Region Association: None |
So if my thermo time switch is bad it would cause the cold start valve to stay on?
If so it would cause the engine to run rich and also foul up the plugs right? Also I can't find the thermo time switch for sell anywhere. |
JeffBowlsby |
Aug 19 2012, 05:43 PM
914 Wiring Harnesses Group: Members Posts: 8,526 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The thermoswitch simply completes the ground path related to engine temp. The usually fail open, so no, the CSV would not work then....but the CSV iteslf may be leaking and cause a rich condition.
pilothyer |
Aug 19 2012, 05:59 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
The 1.7 uses a thermo switch only, not a thermo-time switch. If it fails causing a short to ground it would cause the cold start valve to operate regardless of the engine's temperature, but this would only occur while the starter was engaged. The most common failure mode, however, is that it is open and will not supply ground to the cold start valve even when cooled to 30 below zero. If your cold start valve is the culprit causing an overly rich situation it is most likely because the cold start valve itself is leaking........(test it by removing the valve while it is still connected to the fuel loop and pressurize the system. If it is even just wet on the end it is a leaker) You can reinstall it and remove and plug the fuel line to it untill you replace it........if you think you really need one.....While I was busy taking the long way to say it, Jeff said just about the same thing in the above post (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 01:11 PM |
