Are these 911 hubs & 914/6 stub axels? |
Pesky 914 |
Oct 24 2004, 08:13 PM
Newbie Group: Members Posts: 42 Joined: 22-March 04 From: About to pass you... Member No.: 1,835 |
Can someone tell me if this is a 911 rear hub or a drilled 914/4 hub (I think it's a 911 hub sinec I only see one hole...).
Also, what are a pair of 914/6 stub axles w/911 rear hubs worth? |
Pesky 914 |
Oct 24 2004, 08:16 PM
the hub
Attached image(s) |
736conver |
Oct 24 2004, 08:17 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
They dont look like redrilled 4. They are most likey 911, 914-6
Pesky 914 |
Oct 24 2004, 08:25 PM
QUOTE(736conver @ Oct 24 2004, 06:17 PM) They dont look like redrilled 4. They are most likey 911, 914-6 Isn't the difference between 914/4 and 914/6 stub axles the number of splines? How many does each one have? (I figure I can count mine just to make sure) |
Aaron Cox |
Oct 24 2004, 08:27 PM
those look like 911 or 914/6 hubs (are they the same??? (IMG:style_emoticons/default/wacko.gif) ) the two holes on the hub are threaded for the rotor to be held down by a screw or 2
Pesky 914 |
Oct 24 2004, 08:35 PM
Are these hubs & half shafts (w/ the 914/6 stub axles) worth anything? (yes, I'm parting out my car after a little, er, "incident" at Lime Rock in Sept...)
J P Stein |
Oct 24 2004, 09:05 PM
QUOTE(Pesky 914 @ Oct 24 2004, 06:35 PM) Are these hubs & half shafts (w/ the 914/6 stub axles) worth anything? (yes, I'm parting out my car after a little, er, "incident" at Lime Rock in Sept...) Yes indeedie. Prolly worth somewhere around $400-600...or what ever you can get on evilbay (IMG:style_emoticons/default/biggrin.gif) Parting a race car.....whut else ya gots? |
nickg |
Oct 24 2004, 09:36 PM
Senior Member Group: Members Posts: 501 Joined: 30-August 04 From: franklin, nj Member No.: 2,652 |
wow, i listed mine for 300 and had like 5 guys saying i was crazy high....go figure. and 911 and 914-6 hubs are the same if you use early 911 rear hubs
J P Stein |
Oct 24 2004, 10:20 PM
Hubs & stub axles together would prolly be worth that much.
type47fan |
Oct 24 2004, 10:40 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
Should be a P/N cast into the backside of the hub: 901 331 065 XX (the -6 didn't have the three hub centric lugs{?})
Wayne (type47fan) |
Pesky 914 |
Oct 27 2004, 05:58 AM
QUOTE(J P Stein @ Oct 24 2004, 07:05 PM) Parting a race car.....whut else ya gots? I'll post something in the race classifieds with what I have. |
davep |
Oct 27 2004, 09:43 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Definitely 911 rear hubs. The extra big hole there is for the parking brake adjust. Don't know if the 914/6 had it or not. Someone please verify. As a set, the hubs and stub axles are certainly worth good money. Even better is the trailing arms and axles complete.
Lo-Fi Version | Time is now: 2nd June 2024 - 03:37 AM |
