| solex |
Aug 20 2012, 07:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I have had this problem for some time but cannot determine the cause. The front end rattles particularly when the wheels are turned and I go over a bump.
I had the car jacked up and could not find anything that is obviously loose. I checked the wheel bearings an they are all good. The front dampers look like they can be replaced as they show signs of leaking (a while ago), but the front end is not bouncy. Regards, Dan |
| Van914 |
Aug 20 2012, 07:45 AM
Van914 ![]() ![]() ![]() Group: Members Posts: 702 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest
Sway bar
| solex |
Aug 20 2012, 07:54 AM
| JStroud |
Aug 20 2012, 07:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
| dlestep |
Aug 20 2012, 07:58 AM
I am smilin'... ![]() ![]() ![]() Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
Do you feel it through the steering wheel ?
Check the rubber interface between the shaft and steering box. or you can check the cover on the shock. It could be jiggling. Have you lowered your front end ? |
| solex |
Aug 20 2012, 08:09 AM
(1) The front end has not been lowered.
(2) I replaced the bellows on one side of the rack but assume that is not what you are referring to, so I will pull the bellows back and check (3) I do feel it in the steering wheel and will check the rubber disk between the steering wheel and the rack, I assume I need to remove the tank for this? (4) Will check the dampener covers as well Thanks for the ideas gentlemen Dan |
| matthepcat |
Aug 20 2012, 08:46 AM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
You might want to try pulling the top strut sleeve off, and see if the strut collar(nut or whatever you call it) is loose.
| SLITS |
Aug 20 2012, 01:44 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
You might want to try pulling the top strut sleeve off, and see if the strut collar(nut or whatever you call it) is loose. (IMG:style_emoticons/default/agree.gif) |
| solex |
Aug 20 2012, 03:13 PM
This will involve removing the top of the strut correct?
| SLITS |
Aug 20 2012, 03:20 PM
| matthepcat |
Aug 20 2012, 03:48 PM
Often you can just unbolt the at the top, tap the strut shaft most the way through the rubber mount, and that will give you enough clearance to lift up the upper strut sleeve to reveal the shock collar/nut .
A big set of slip joint pliers will give you enough torque to tighten it down without fully removing it. |
| solex |
Aug 25 2012, 06:25 PM
Thanks all, it was the strut collar, not sure why but the drivers side was loose, tightened down no more rattling in the front end..
In checking the dampers I noticed that the collapse about 3/4 of the way and then need to be compressed to the bottom. They are not leaking (boge) and they look good. Just wondering as all other struts and springs that I have dealt with need to be compressed as their normal mode is fully extended. The front end does not bounce around so I'm thinking that the dampers are ok, what do you think? |
| Eric_Shea |
Aug 25 2012, 07:14 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Normal mode is fully extended on "gas pressurized" struts. Hydraulics can rest in any position. The fact that they collapse and then begin to compress would have me shopping for new inserts.
| solex |
Aug 25 2012, 07:17 PM
will start shopping...
Lo-Fi Version | Time is now: 9th June 2026 - 02:09 AM |
