Headlights pop up on first notch of switch?, Should stay down and just parking lights on...right? |
Mr.242 |
Aug 20 2012, 11:08 PM
May your glass be smaller so it's always FULL! Group: Members Posts: 1,079 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
I'm looking for a fix or what I did wrong when I re-installed my parts on my car. I know they should remain down when the first notch of dash switch is engaged. But for some reason mine pop up, no headlights, I know this isn't correct.
Advice? I'm sure there is something simple I did wrong on my install. Thanks in advance. Mark |
sixnotfour |
Aug 20 2012, 11:41 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Its a 70, thats how they roll...There is a simple mod to make it like you think it should be.
toolguy |
Aug 21 2012, 12:08 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
actually, that is how they are suppose to work on a 914-6 . . the lead that controls 'head light up' to the motors is the gray wire on terminal K on the headlight switch. . . is you want the headlights to stay down until the 3rd stop on the headlight switch, move the gray lead from K to 56 on the switch. This will allow you to run your fogs with the tail and side markers on and keep the headlight down. . Handy if you're running at sundown with a bra on the car and don't want to stop and fold down the flaps. .
djm914-6 |
Aug 21 2012, 06:19 AM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
Looks like I need to look at the wiring on my switch. Mine pop on the first notch too.
able2222 |
Aug 21 2012, 06:42 AM
Newbie Group: Members Posts: 30 Joined: 29-July 09 From: Austin, TX Member No.: 10,621 Region Association: None |
Way back in '70 when I bought mine we changed the wiring so the headlights were up but not on with the switch. It was easier to clean the bugs and crud off the headlight lens than it was to clean and repair chips and crud off the painted covers.
Mr.242 |
Aug 21 2012, 10:21 AM
I will do some work on that switch and get it to where I can keep them down and run the fog lights and parking lamps.
Thanks! |
Lo-Fi Version | Time is now: 10th June 2024 - 03:34 AM |
