Mr.242
Aug 20 2012, 11:08 PM
I'm looking for a fix or what I did wrong when I re-installed my parts on my car. I know they should remain down when the first notch of dash switch is engaged. But for some reason mine pop up, no headlights, I know this isn't correct.
Advice? I'm sure there is something simple I did wrong on my install. Thanks in advance. Mark
sixnotfour
Aug 20 2012, 11:41 PM
Its a 70, thats how they roll...There is a simple mod to make it like you think it should be.
toolguy
Aug 21 2012, 12:08 AM
actually, that is how they are suppose to work on a 914-6 . . the lead that controls 'head light up' to the motors is the gray wire on terminal K on the headlight switch. . . is you want the headlights to stay down until the 3rd stop on the headlight switch, move the gray lead from K to 56 on the switch. This will allow you to run your fogs with the tail and side markers on and keep the headlight down. . Handy if you're running at sundown with a bra on the car and don't want to stop and fold down the flaps. .
djm914-6
Aug 21 2012, 06:19 AM
Looks like I need to look at the wiring on my switch. Mine pop on the first notch too.
able2222
Aug 21 2012, 06:42 AM
Way back in '70 when I bought mine we changed the wiring so the headlights were up but not on with the switch. It was easier to clean the bugs and crud off the headlight lens than it was to clean and repair chips and crud off the painted covers.
Mr.242
Aug 21 2012, 10:21 AM
I will do some work on that switch and get it to where I can keep them down and run the fog lights and parking lamps.
Thanks!
