Wipers won't park, Can't remember how to fix this problem |
IronHillRestorations |
Aug 28 2012, 01:53 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've got a car coming my way for a short list of small minor issues to fix. One of the problems is the wipers won't park properly. It's been over ten years since I've addressed this problem and I can't remember the fix.
Valy |
Aug 28 2012, 02:07 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
replace wiper switch
tomeric914 |
Aug 28 2012, 07:29 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Check to see if it has intermittent wipers. Replace the relay if it's missing. Then make sure the ground is in place.
ThinAir |
Aug 28 2012, 10:58 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Mine won't park unless I shut them off within just the right range from the bottom of the stroke. I don't have intermittent wipers (although I'd like to). Is it really certain that this kind of thing is the wiper switch? That's easier than a problem with the wiper motor.
ThinAir |
Aug 30 2012, 10:30 PM
daniel951 |
Oct 30 2012, 12:10 PM
Newbie Group: Members Posts: 13 Joined: 21-January 12 From: evansville indiana Member No.: 14,036 Region Association: None |
make sure there is power on the park circuit of the motor.
could be an issue with the park points in the motor as well. hope that helps |
76-914 |
Oct 30 2012, 03:02 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
mine happened when one pin in the intermittent relay slipped and wasn't making contact. IIRC, it was the grnd from turn signal assm. Possibly white w/ brn strip???
Lo-Fi Version | Time is now: 9th June 2024 - 06:56 PM |
