| Brian_Boss |
Aug 29 2012, 07:49 PM
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
Here's the thread where it was discussed:
http://www.914world.com/bbs2/index.php?s=&...t&p=1224720 If no one is actively working on it, I would take it on if someone could send me a cast or impression of a factory 6 dash. Or am I the only one who thought that it was a cool idea... |
| Mike Bellis |
Aug 29 2012, 08:44 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Does anybody make the switch?
| MikeSpraggi |
Aug 29 2012, 10:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
| mharmon |
Aug 30 2012, 09:05 AM
Member ![]() ![]() Group: Members Posts: 131 Joined: 1-November 06 From: Los Angeles Member No.: 7,133 |
The 914/6 ignition switch and housing have been supersceded to 964 part numbers. Both are available new from the dealer.
| McMark |
Aug 30 2012, 02:23 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
| SirAndy |
Aug 30 2012, 02:48 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The 914/6 ignition switch and housing have been supersceded to 964 part numbers. Both are available new from the dealer. (IMG:style_emoticons/default/agree.gif) I used a 911 switch for my conversion ... http://www.914world.com/bbs2/index.php?showtopic=82045 (IMG:style_emoticons/default/driving.gif) |
| JmuRiz |
Aug 30 2012, 04:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
I was going to buy sixnotfour's dash switch but he ended up using on a conversion car he bought. I'd love to have a dash key on my conversion.
| Brian_Boss |
Aug 30 2012, 06:15 PM
Just to clarify, I'm talking about the recessed area of the dash sheet metal. The 911 dash is perpendicular to the steering column while the 914 is not. As a result, the ignition lock is not perpendicular to the dash. The factory six cars have an angled depression in the dash to accommodate the difference in angle.
People (myself included) have fabricated a piece by folding sheet steel but it is time consuming and not "right" IMHO. In the thread linked in my original post, there was a discussion about duplicating this area of the original dash. The 914/6 ignition switch and housing have been supersceded to 964 part numbers. Both are available new from the dealer. |
| Brian_Boss |
Aug 30 2012, 06:19 PM
| sixnotfour |
Aug 30 2012, 07:00 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
This uses the stock 914 igntion switch and wiring,,,,Looks like a -6,,, but aint..... custom switch mount and bezel. Thats it.. no other wiring.. For those who are Left inclined.
Notice -6 column ...no steering lock. oh well??====cheap igniton switch, Attached image(s)
| rhd914 |
Aug 30 2012, 07:08 PM
Newbie ![]() Group: Members Posts: 44 Joined: 11-November 03 From: Australia Member No.: 1,332 |
I'm interested.
| edwin |
Aug 30 2012, 09:50 PM
Member ![]() ![]() Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
I've been thinking about doing this convesion but the parts never seem to be available together. is there somewhere i should be looking?
Supply of early porsche stuff here downunder is hard to find or crazy expensive. Cheers Edwin |
| John |
Aug 30 2012, 10:00 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
It's a lot of work, but I made my own recessed plate that mounted the key switch.
Mine is fully functional (steering lock included). It is a 1973 or earlier 911 steering column and ignition switch / lock. There are provisions existing in the body sheet metal to incorporate the 911 or 914 steering column lock mechanism. The 911 steering column has to be modified to bolt into the 914 body. I had a thread from when I did mine, but am traveling at the moment and am too lazy to search for it. Good luck with your project. |
| SirAndy |
Aug 31 2012, 02:39 PM
Just to clarify, I'm talking about the recessed area of the dash sheet metal. The 911 dash is perpendicular to the steering column while the 914 is not. As a result, the ignition lock is not perpendicular to the dash. The factory six cars have an angled depression in the dash to accommodate the difference in angle. I would take one. I reworked the 911 piece to (sort of) work with my dash and it's OK, but if you had a nice piece that actually fit better, i'd go with that. (IMG:style_emoticons/default/chowtime.gif) |
| Harpo |
Apr 6 2013, 04:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I would be interested in this as well. I have just started to assemble the components to build the 914-6 clone steering column.
Thanks DAvid |
| Harpo |
Apr 7 2013, 11:57 AM
For the short term would someone be willing to make a cast of their 914-6 ignition switch depression?
Thanks David |
| Harpo |
Apr 8 2013, 06:50 AM
I will be making a cast this weekend of the 914-6 ignition switch depression. I will be just using bondo unless anyone has a better idea
David |
| McMark |
Apr 8 2013, 10:02 AM
Make sure to use a good amount of mold release wax on the dash. (IMG:style_emoticons/default/wink.gif)
| Harpo |
Apr 8 2013, 11:00 AM
I probably don't have access to mold release wax. Will any wax do?
Thanks David |
| mr914 |
Apr 8 2013, 04:22 PM
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
David
Plain old Johnson paste wax works fine for making a bondo splash. Add some tape to cover the holes. brush it on with a $2 brush and mix up the bondo. Let it sit for about an hour and pop it off. Repeat for the back side. Will be arriving back from JPL DSN Goldsone late friday night. About noon will work for me. If the weather is decent, I may start pulling the driveline out of the 6 conversion on Saturday. Keith |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:00 PM |
