kbrunk1 |
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States ![]() |
Do you have to use the $12 each Fuel Injector Line Elbow's
What happens if you just use fuel line? Are folks buying 8mm fuel line? Where? Thanks |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
If the line kinks from bending, it will effect the fuel flow... That's why they have elbows.
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
You can use fuel line. But you'll need to leave them longer so they don't kink.
My .02c. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,188 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
It is bent for a reason.
walterolin |
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States ![]() |
FWIW I've run fuel line on a 1.7 for 35 years. I change the lines about every for years, and as Cary said above, I leave them a little long so they won't kink. You have to pull them back when you drop the engine.
Olin |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,829 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
If you consider they'll probably last at least 10 years, why not get the real deal?
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
7mm ID or 5/16ths line work well. I though you could also go super short on them, so there is only a fraction amount of hose between the injector and rail. Might be worth testing. It will drop the rails down abit lower. With the longer lines, I didn't like the way it was butted up under the MPS. Alot of guys are using the R009 rated fuel line now to combat the ethenol gas.
BMW also has rubber elbows that are much cheaper than the OEM ones. They are probally 8mm ID. Should be a thread somewhere on it. |
pilothyer |
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States ![]() |
Another "point to ponder" is, Can you get the new elbows in the newer "Flex Fuel" grade for Ethanol mix fuel ??????? If not you may have to skip the preformed elbows.
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Another "point to ponder" is, Can you get the new elbows in the newer "Flex Fuel" grade for Ethanol mix fuel ??????? If not you may have to skip the preformed elbows. Good point (IMG:style_emoticons/default/popcorn[1].gif) Biggest problem I see is in dropping the engine. Without the elbows, they will get hung up in the engine shelf. You have to be extra careful when dropping the engine. |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
mps side can not be long
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I cut a short length of hose, zip tie tight thru the hose and around a 1 1/2" dowel or pipe, and use a heat gun to soften it slightly. When it cools, the bend stays.
I don't cook it, just warm enough to make it unpleasant it to touch. |
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
I popped for the OE bent ones. Not cheap but heck it gasoline going through there in a hot engine room.
Lo-Fi Version | Time is now: 8th July 2025 - 03:53 PM |
