| rgolia |
Aug 31 2012, 08:44 AM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 720 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
My temp gauge doesn't move. I installed a new sender and still no movement. It does move (just a little) when the ignition is turned on so it is getting power.
| SLITS |
Aug 31 2012, 09:20 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
With power on to gauge, ground the sender wire and it should move full scale.
Do you have a ground wire connected to the gauge itself? |
| rgolia |
Aug 31 2012, 11:35 AM
I will try that test...thanks. The original 3 pong connector is how it is attached.
| rgolia |
Oct 1 2012, 01:04 PM
Did the test and the gauge works. The wire to the sender was faulty. Installed a new sender wire. Now that the gauge works, is there a way to get more fluctuation out of it. It seems to stay in the very low range regardless of driving conditions.
| timothy_nd28 |
Oct 1 2012, 01:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
you could lean out your motor
| damesandhotrods |
Oct 1 2012, 02:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
Did the test and the gauge works. The wire to the sender was faulty. Installed a new sender wire. Now that the gauge works, is there a way to get more fluctuation out of it. It seems to stay in the very low range regardless of driving conditions. When I was in Portland Oregon, my temperature gauge never moved, I was beginning to suspect something was wrong with it. But once I moved to California I found it worked normally. |
| 76-914 |
Oct 1 2012, 03:45 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,878 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
are your sender and gage a matched pair. look on the sender, it is stamped with it's range on the side of the sender.
Lo-Fi Version | Time is now: 14th April 2026 - 05:34 AM |
