| Deano |
Oct 26 2004, 06:01 PM
Member ![]() ![]() Group: Members Posts: 83 Joined: 13-October 04 From: Des Moines, Iowa Member No.: 2,942 |
I am in the process of repairing the longs on my car, pretty straight forward, except the jack posts had been removed by the PO. I have the replacement pieces and am not sure of proper set up. How far into the support should the tube go? Do I weld the tube to the support first, then to the car? Does the tube get welded to the car or just to the support? HELP!!!!! All of the photos and illustrations I can find really don't help.
| Porsche Rescue |
Oct 26 2004, 06:07 PM
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I want to know too.
| balljoint |
Oct 26 2004, 07:08 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,001 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
Measurements to indicate location might also be usefull.
| ejm |
Oct 26 2004, 07:49 PM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,717 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Best way to locate the tube is to use the hole in the outer rocker as a guide. Weld the tube to the inner rocker, then install the support plate. The fender will be in the way and you won't be able to get the support in place. Make cuts in the support 1" down from the support's tube hole and bend the tab down to get clearance, then weld it back up. The bottom of the factory jack hole actually sits about 1" inside the inner rocker. If the whole jack post area was rotted and repaired flush with the rocker the new jack tube will stick out too far.
| Deano |
Oct 26 2004, 08:01 PM
That's nice to know, I would have never thought to cut it. I am going to repair the area flush,
so how far out from the outer rocker should it stick? I had been planning to use the outer rocker to determine location. |
| mercdev |
Oct 26 2004, 08:37 PM
Read, search, then read some more ![]() ![]() Group: Members Posts: 166 Joined: 19-July 04 From: Overland Park, KS Member No.: 2,374 |
1 view (both right side)
| mercdev |
2nd
| Deano |
Oct 26 2004, 09:11 PM
Great Pix. Thanks that helps a lot. When your outer rocker is in place is the post pretty much flush?
| mercdev |
Oct 26 2004, 09:53 PM
QUOTE(Deano @ Oct 26 2004, 10:11 PM) Great Pix. Thanks that helps a lot. When your outer rocker is in place is the post pretty much flush? Yes. There's maybe 1/8 to 1/16 gap, but the plug fits snug when it's in so I don't think that matters. The tube also is snug against the rocker (no rear gap that I can see), fyi. |
| Deano |
Oct 26 2004, 09:59 PM
Excellent, thanks to everyone again. Your help is always appreciated.
Lo-Fi Version | Time is now: 27th June 2026 - 04:30 PM |
