HandBrake Lever Bolt, Am I missing something? |
bperry |
Sep 13 2012, 02:08 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
After many years I'm repairing my handbrake (repairing broken pivot on handbrake stand)
and while I've not changed the hex head bolt from the way I bought the car 28 years ago, I can't help but feel that it isn't correct or that something is missing. There seems to be something not quite correct in the way things fit together. I'm wondering if the bolt should be a shoulder bolt of if I'm missing some sort of stand off that sleeves the bolt. Below is a bottom view of the handbrake stand with the bolt going through the ratchet. It is loose but you can see that there is a threaded area that is inside the hole for the ratchet. If you look at the parts diagram: There is a hex bolt. Item #18 part number 900 075 085 02 It is listed as a "Hexagon head bolt M8x20". Then there is item #17 part number 900 027 015 02 It is listed as "Lock ring B 8" Is this a standoff/bushing or just a simple lock washer? So my question what it is supposed to be there? - A special shoulder bolt - A M8x20 bolt with a special standoff/bushing (Is that what item #17 is?) - A M8x20 bolt that is just cranked down with a lock washer (what was there but doesn't seem correct) The reason I'm asking is that the hole in the ratchet seems larger than necessary given the bolt size and it seems odd to have bare threads exposed to the ratchet. Plus the lever seems like it would be more stable if the hole closer matched the bolt size or used some sort of standoff/bushing. --- bill |
SLITS |
Sep 13 2012, 04:57 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
From your image, it appears that someone has spaced the rachet and paul out from the body.
1.) the bolt appears to be to long ... M8X20 is 20 mm long ... it should be about 3/4" long. Toothed plate should be against the body, slipped over the boss for the bolt threads. 2.) The handle assembly is also spaced away from the body mount. It rides on a stud with a plastic bushing. Hey, that's what I see anyway! |
76-914 |
Sep 13 2012, 05:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
SLITS |
Sep 13 2012, 05:46 PM
I was wrong as it doesn't slip over the boss, but is certainly bolted up against it tight. It is not supposed to move; it's locked into place.
bperry |
Sep 13 2012, 06:02 PM
From your image, it appears that someone has spaced the rachet and paul out from the body. 1.) the bolt appears to be to long ... M8X20 is 20 mm long ... it should be about 3/4" long. Toothed plate should be against the body, slipped over the boss for the bolt threads. Actually the spacing is original and the bolt is the right size. The overall design is a bit odd with what seems like a little bit of slop built into it. (The toothed plate is not really locked in place and is allowed to rotate a few degrees) I had the bolt loose in the earlier photo to show the threads to show that it wasn't a shoulder bolt. You can see in these photos that there is no additional spacing but also that there is no washer/bushing between the bolt head and the toothed plate. QUOTE 2.) The handle assembly is also spaced away from the body mount. It rides on a stud with a plastic bushing. Yep the handle/lever rides against the stand on a natural spacer built in to the assembly. (Plastic bushing is currently removed - is being replaced with a new one once I refinish the handle) My question really was about the bolt and the washer/bushing. Is the bolt just a simple M8x20 that is fully threaded vs a shoulder bolt with a larger diameter near the hex head to better fit the toothed plate? (I'm now assuming it is a simple 8x20 fully threaded bolt) In this photo, is the spacer between the bolt and the toothed plate a washer, a lock washer or an actual bushing that slips into the toothed plate? --- bill |
SLITS |
Sep 13 2012, 10:38 PM
As I remember, it is a lock washer.
And the toothed plate doesn't move when tightened down. |
bcheney |
Sep 14 2012, 04:14 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Just installed mine. Here is what it looks like. I lost my bolt...looked it up on the PET and found a 8x20mm sized one in my stash. Everything works fine.
Attached thumbnail(s) |
bcheney |
Sep 14 2012, 04:17 AM
Hope the pic helped
Lo-Fi Version | Time is now: 10th June 2024 - 08:28 PM |
