Brandon113 |
Newbie ![]() Group: Members Posts: 10 Joined: 17-August 12 From: Bedford, Texas Member No.: 14,818 Region Association: Southwest Region ![]() |
I have rusted out jack points and the tubes are in bad shape but the longs are in great shape. My question is the tube is welded to a plate that covers the long and then has the pyramid shaped plate welded on top that the tube passes through. I can not seem to find the flat plate that welds to the long and the tube. Once I removed the rusted tube there is a inspection hole in the long under the flat mounting plate. I don't see any of this in the diagrams. Am I missing some thing? I can form a new plat out of 18 gauge sheet and tig it in place but would like to see what it looked like as my is rusted away. There is front reinforcemrnt box that is welded to the front of the long just about under the door hinge wondering if anyone makes one of these ?
Thanks Brandon |
wingnut86 |
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States ![]() |
Brandon,
You have just discovered why sooo many 914s spend years on jackstands (IMG:style_emoticons/default/smile.gif) We need photos with the best lighting and image quality possible, still keeping under the image post size. Many more will jump in and help, ridicule and expess sympathies once you do so. Good luck & welcome to hell (IMG:style_emoticons/default/happy11.gif) Dave I have rusted out jack points and the tubes are in bad shape but the longs are in great shape. My question is the tube is welded to a plate that covers the long and then has the pyramid shaped plate welded on top that the tube passes through. I can not seem to find the flat plate that welds to the long and the tube. Once I removed the rusted tube there is a inspection hole in the long under the flat mounting plate. I don't see any of this in the diagrams. Am I missing some thing? I can form a new plat out of 18 gauge sheet and tig it in place but would like to see what it looked like as my is rusted away. There is front reinforcemrnt box that is welded to the front of the long just about under the door hinge wondering if anyone makes one of these ? Thanks Brandon |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,680 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,728 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Both parts are available from restoration design & fairly inexpensive. They are one of the advertisers on this site. Check the top of this page.
Lo-Fi Version | Time is now: 10th June 2024 - 06:25 PM |
