jersey914 |
Member ![]() ![]() Group: Members Posts: 161 Joined: 6-September 12 From: Marlton, NJ Member No.: 14,895 Region Association: North East States ![]() |
My turn signals do not turn off automatically after making left or right turns and I want to make the necessary repairs. Can someone refer me to a tutorial thread or explain what I need to do to fix this issue. I an guessing I have broken parts inside the steering column so if that is indeed your suspicion, I could use a referral to a parts source as well. |
ellisor3 |
HPWhore ![]() ![]() ![]() Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States ![]() ![]() |
There is a cancelling ring inside there that can shear off or wear down over time. It is easier to simply replace the whole assembly while you are in there. I would check the VW sites to find the turn signal replacement. It is much cheaper to buy it as a VW part than a Porsche Part eventhough they are the same. There are several threads about this replacement. Seems like I saw one just a few weeks ago.
Found the part numbers on Jeff's site: VW Part # 914 Year VW Model/Year Turn signal switch 311.953.513B 1970-71 VW 1968-70 Beetle Turn signal switch 111.953.513C 1971 VW 1971 Beetle Turn signal switch 914.613.913.14 1972-74 VW 1972-79 Beetle Turn signal switch 914.613.913.15 1975-76 VW 1975-76 |
mrholland2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California ![]() |
Mine was doing this.
Took off the steering wheel and cleaned some of the crud out with an air hose Works now, although slowly so I'm going to use some other junk in there to clean out more crud. |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
You might also check the upper bearing bushing too make sure it's good. Mine was so loose the horn would hink when you hit a bump.
eg914 |
Member ![]() ![]() Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None ![]() |
Have you checked the condition of the tab on the horn/signal cancel ring on the back of the steering wheel? If this is worn or broken the signal won't cancel. If this is the problem you can get a replacement t a VW shop. Make sure you get the correct connector size on the wire,there are narrow and wide.
jersey914 |
Have you checked the condition of the tab on the horn/signal cancel ring on the back of the steering wheel? If this is worn or broken the signal won't cancel. If this is the problem you can get a replacement t a VW shop. Make sure you get the correct connector size on the wire,there are narrow and wide. I have not done anything yet, I was waiting to get some recommendations. Thanks |
Lo-Fi Version | Time is now: 19th July 2025 - 11:23 AM |
